intake sellection for 511 #2060569
04/24/16 12:41 AM
04/24/16 12:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What intake have you guys found to make good power on a lo deck 511 with victor heads? open plenum. everything needs to fit under a 6 pak hood in an A body. Thanks
Re: intake sellection for 511 [Re: mopar dave] #2060588
04/24/16 01:02 AM
04/24/16 01:02 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I think an M1 would be your best bet.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: intake sellection for 511 [Re: DARTH V8Я] #2060626
04/24/16 02:20 AM
04/24/16 02:20 AM
Mt Morris Michigan
Mt Morris Michigan
i forgot about those. i will check those out.
Re: intake sellection for 511 [Re: DARTH V8Я] #2060733
04/24/16 11:46 AM
04/24/16 11:46 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What M1 intake has MW ports AND fits a low-deck build?
At this time, the only low-deck MW intake I can think of is an Indy SP, in either a 4150 or 4500 flange version. Not short, though.
Re: intake sellection for 511 [Re: mopar dave] #2060790
04/24/16 01:27 PM
04/24/16 01:27 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
You could use an Indy Mod man with a single 4. It has MW ports. That Indy single plane is the only MW manifold on the market. I have one under the hood of my 71 Charger. But it has a bulge hood. Use a R2N drop air filter base as well.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: intake sellection for 511 [Re: mopar dave] #2060792
04/24/16 01:29 PM
04/24/16 01:29 PM
AndyF Offline
AndyF  Offline
Std port or MW port? Like Brad says, MW port means Indy. Std port gives you more options.
Re: intake sellection for 511 [Re: mopar dave] #2060824
04/24/16 02:26 PM
04/24/16 02:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the 383 Victor fully ported w/a 2" adapter and it fits (barely) under my 6-pack scoop w/a 3 1/2" wix filter..........standard port.......
Re: intake sellection for 511 [Re: mopar dave] #2060957
04/24/16 07:15 PM
04/24/16 07:15 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Doesn't Indy make a dual-plane that they hog out to MW size for an extra $100. ??
Re: intake sellection for 511 [Re: BradH] #2060981
04/24/16 08:05 PM
04/24/16 08:05 PM
Mt Morris Michigan
Mt Morris Michigan
Thought i seen a m1 for 383 on ebay. Heads are victors standard port cnc'd. 332cc
Re: intake sellection for 511 [Re: mopar dave] #2061044
04/24/16 09:46 PM
04/24/16 09:46 PM
BradH Offline
BradH  Offline
If you bought Todd's heads that were CNC ported by Hughes, I'm pretty sure those ARE Max Wedge ports.
Re: intake sellection for 511 [Re: mopar dave] #2061045
04/24/16 09:46 PM
04/24/16 09:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
On your deal for race only I would choose the Eddy Victor 383, on a street and strip deal with mostly street I would opt for the Eddy Performer RPM with at least a 850 CGM carb. or bigger thumbs twocents
Re: intake sellection for 511 [Re: Stanton] #2061046
04/24/16 09:49 PM
04/24/16 09:49 PM
BradH Offline
BradH  Offline
RB only; no Indy dual-plane for low deck.
Re: intake sellection for 511 [Re: BradH] #2061060
04/24/16 10:09 PM
04/24/16 10:09 PM
Mt Morris Michigan
Mt Morris Michigan
i'm not sure. he told me 332cc. Thats the same size port as my Indy 360-1's i'm about to sell.
Re: intake sellection for 511 [Re: Cab_Burge] #2061061
04/24/16 10:12 PM
04/24/16 10:12 PM
Mt Morris Michigan
Mt Morris Michigan
i'm not sure that victor would fit under my 6pak hood. anyone know how much taller the the victor is compared to the rpm?
Re: intake sellection for 511 [Re: mopar dave] #2061066
04/24/16 10:15 PM
04/24/16 10:15 PM
BradH Offline
BradH  Offline
Todd's heads are MW, and I think an Indy 360-1 is 90 to 100 cc smaller than those MW Victors, if they're really 332 cc.
Re: intake sellection for 511 [Re: BradH] #2061076
04/24/16 10:25 PM
04/24/16 10:25 PM
Mt Morris Michigan
Mt Morris Michigan
he measured and told me 332cc, maybe he just typed it wrong?
Re: intake sellection for 511 [Re: mopar dave] #2061091
04/24/16 10:42 PM
04/24/16 10:42 PM
BradH Offline
BradH  Offline
Hughes says the standard CNC port like I have is 313 cc. The pics Todd sent me of those heads "way back when" definitely had larger intake ports than mine, so a 332 cc MW port is probably correct.
Re: intake sellection for 511 [Re: mopar dave] #2061104
04/24/16 10:59 PM
04/24/16 10:59 PM
AndyF Offline
AndyF  Offline
If those are standard port heads then I'd run either the Trick Flow intake with a 4150 carb or the Mopar M1 4500 with a Dominator. If your heads are MW ports then you are stuck with the choices from Indy. You should measure the ports so you know for sure what you have. If the ports are smaller than a MW then you might be able to use a standard port intake and open it up a bit. Just really depends on what you have.
Re: intake sellection for 511 [Re: AndyF] #2061173
04/25/16 01:05 AM
04/25/16 01:05 AM
Mt Morris Michigan
Mt Morris Michigan
ok yes i will check those out. i will figure that out when i get them. Todd is still finishing them up. any of these any good for making power on a 511, tm6, team G? I plan on running a dominator only on this combo. thanks guys
Re: intake sellection for 511 [Re: mopar dave] #2061203
04/25/16 02:34 AM
04/25/16 02:34 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Team G is the bottom of the barrel. TM 6 is great on 450CI or less, 511, depends what your after. Max performance or other. Neither, if max power is the goal.
