Re: intake sellection for 511
[Re: mopar dave]
#2060588
04/24/16 01:02 AM
04/24/16 01:02 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I think an M1 would be your best bet.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2060733
04/24/16 11:46 AM
04/24/16 11:46 AM
BradH
I think an M1 would be your best bet. What M1 intake has MW ports AND fits a low-deck build? At this time, the only low-deck MW intake I can think of is an Indy SP, in either a 4150 or 4500 flange version. Not short, though.
[Re: mopar dave]
#2060790
04/24/16 01:27 PM
04/24/16 01:27 PM
Posts: 326 Alberta
Wookie316
Alberta
You could use an Indy Mod man with a single 4. It has MW ports. That Indy single plane is the only MW manifold on the market. I have one under the hood of my 71 Charger. But it has a bulge hood. Use a R2N drop air filter base as well.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: mopar dave]
#2060792
04/24/16 01:29 PM
04/24/16 01:29 PM
Posts: 31,050 Oregon
AndyF
What intake have you guys found to make good power on a lo deck 511 with victor heads? open plenum. everything needs to fit under a 6 pak hood in an A body. Thanks Std port or MW port? Like Brad says, MW port means Indy. Std port gives you more options.
[Re: mopar dave]
#2060824
04/24/16 02:26 PM
04/24/16 02:26 PM
Thumperdart
State of confusion
I run the 383 Victor fully ported w/a 2" adapter and it fits (barely) under my 6-pack scoop w/a 3 1/2" wix filter..........standard port.......
[Re: mopar dave]
#2061044
04/24/16 09:46 PM
04/24/16 09:46 PM
BradH
Thought i seen a m1 for 383 on ebay. Heads are victors standard port cnc'd. 332cc If you bought Todd's heads that were CNC ported by Hughes, I'm pretty sure those ARE Max Wedge ports.
[Re: Stanton]
#2061046
04/24/16 09:49 PM
04/24/16 09:49 PM
BradH
Doesn't Indy make a dual-plane that they hog out to MW size for an extra $100. ?? RB only; no Indy dual-plane for low deck.
[Re: mopar dave]
#2061066
04/24/16 10:15 PM
04/24/16 10:15 PM
BradH
i'm not sure. he told me 332cc. Thats the same size port as my Indy 360-1's i'm about to sell. Todd's heads are MW, and I think an Indy 360-1 is 90 to 100 cc smaller than those MW Victors, if they're really 332 cc.
[Re: mopar dave]
#2061091
04/24/16 10:42 PM
04/24/16 10:42 PM
BradH
he measured and told me 332cc, maybe he just typed it wrong? Hughes says the standard CNC port like I have is 313 cc. The pics Todd sent me of those heads "way back when" definitely had larger intake ports than mine, so a 332 cc MW port is probably correct.
[Re: mopar dave]
#2061104
04/24/16 10:59 PM
04/24/16 10:59 PM
AndyF
Thought i seen a m1 for 383 on ebay. Heads are victors standard port cnc'd. 332cc If those are standard port heads then I'd run either the Trick Flow intake with a 4150 carb or the Mopar M1 4500 with a Dominator. If your heads are MW ports then you are stuck with the choices from Indy. You should measure the ports so you know for sure what you have. If the ports are smaller than a MW then you might be able to use a standard port intake and open it up a bit. Just really depends on what you have.
[Re: AndyF]
#2061173
04/25/16 01:05 AM
04/25/16 01:05 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
ok yes i will check those out. i will figure that out when i get them. Todd is still finishing them up. any of these any good for making power on a 511, tm6, team G? I plan on running a dominator only on this combo. thanks guys
[Re: mopar dave]
#2061269
04/25/16 10:26 AM
04/25/16 10:26 AM
Posts: 326 Alberta
Wookie316
Alberta
[Re: mopar dave]
#2061300
04/25/16 11:24 AM
04/25/16 11:24 AM
Posts: 326 Alberta
Wookie316
Alberta
I wanted to go bigger on the cam. My builder assured me it would be enough for my car. We'll see when I make my first pass this year.
[Re: Wookie316]
#2061304
04/25/16 11:35 AM
04/25/16 11:35 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Dave, Go with the Indy single, IMO your car is light enough so with enough stall (like a tight-ish 8") and compression that you won't have much issue with low end distribution. the 400-2 can be a bit of a Light-switch but with the right cam and weight it won't be bad at all. I've ported Holley street dominators to very close to MW size and they work awesome with a spacer. Do you know your head flow? Remember the Runner CC on the indy's and the victors can be a bit deceptive compared to standard mopar heads since they incorporate the CC volume of a comparable Stage VI intake spacer into the casting. I run the ported MP 337 Single on my low deck (but I have the Chapman Stage V1's) and it'll still "pull the hinges off the gates of He!!" down low. Tell me about those 360-1 heads in a PM, I just bought an R3 block and I'm thinking turbo
[Re: mopar dave]
#2061333
04/25/16 12:40 PM
04/25/16 12:40 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Todd's heads are MW size. For a low deck manifold, afaik there are basically 3 choices for "bolt on" installation and a single carb............Indy 400-2, 400-3, Mod Man.
[Re: mopar dave]
#2061341
04/25/16 12:45 PM
04/25/16 12:45 PM
fast68plymouth
So. Burlington, Vt.
I'll bet you a dollar your 360-1's aren't 330cc(or to put it another way, 85cc's bigger that the CNC 245's).
