Starter Decode Help #2060401
04/23/16 06:11 PM
04/23/16 06:11 PM
MoreParts Offline OP
Hello, I needed some help deciphering this starter core. It's a 2875560
Attached is a pic of what I'd like help decoding. The year number in the sunburst doesn't look too legible to me, but maybe on of you guys with the discerning eyes could make heads or tales of it. The month code looks like May. Any help with a day code or any other info these numbers represent would be a big help!
Re: Starter Decode Help [Re: MoreParts] #2060410
04/23/16 06:46 PM
04/23/16 06:46 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The two numbers in the center of the star pattern are illegible. They would tell you the year of that half of your starter.
Re: Starter Decode Help [Re: MoreParts] #2060416
04/23/16 07:00 PM
04/23/16 07:00 PM
Do you think that could be a "0" at the 1 o'clock position?
Does that 6 mean anything?
Re: Starter Decode Help [Re: MoreParts] #2060436
04/23/16 07:45 PM
04/23/16 07:45 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
I see 73 in the center of the circle = 1973
Re: Starter Decode Help [Re: MoreParts] #2060443
04/23/16 08:08 PM
04/23/16 08:08 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I looked at this thread earlier and thought I saw 73 as well
And months, May for sure, maybe June
Whats the assy date of on the barrel?
Based on how washed out the casting is I'd doubt the assy date will match
Re: Starter Decode Help [Re: MoreParts] #2060446
04/23/16 08:13 PM
04/23/16 08:13 PM
Wow. you guys have some great eyes! On the barrel I just see the part number code. I'll have to squint hard I guess. Would the assembly date be close to the part number?
Re: Starter Decode Help [Re: MoreParts] #2060516
04/23/16 11:12 PM
04/23/16 11:12 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
3 digit code benieth Chrysler and the PN on the barrel
Re: Starter Decode Help [Re: AAR#2] #2060581
04/24/16 12:56 AM
04/24/16 12:56 AM
The barrel is 030. Is that 03-70?
Re: Starter Decode Help [Re: MoreParts] #2060590
04/24/16 01:03 AM
04/24/16 01:03 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
No,
030 is 3rd week of 1970
Re: Starter Decode Help [Re: hemi70se] #2060600
04/24/16 01:31 AM
04/24/16 01:31 AM
Thanks for the clarification. What is the acceptable date range from the build date of the car?
