Re: TKO Vibration in 4th gear
[Re: General 68]
#2059921
04/22/16 08:10 PM
04/22/16 08:10 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Sounds like a fun one to track down.
Are you sure it's not a resonance from the engine or exhaust that is only present at a particular speed and load?
Could it be the driveline balance or angle?
Have you put it on stands and tried it with the wheels off the ground? If not, try it. If it is still there, pull the wheels and try it again. Be sure to secure the rear brake drums/rotors with lug nuts first.
[Re: General 68]
#2060144
04/23/16 03:00 AM
04/23/16 03:00 AM
Posts: 114 Oregon
Wagonman1967
Had the same issue on my Chevelle for years. Tried everything with the muncie setup,drive shaft,pinion angle ect. Finially did the TKO 600 conversion and it was still there. Ditched the poly trans mount and went with the OEM from NAPA IIRC and problem is GONE. It was a resonence type drone with a shifter buzz that I could regulate with the throttle at about 55-65 mph. If you have a Poly mount give it a try.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: Wagonman1967]
#2060406
04/23/16 06:30 PM
04/23/16 06:30 PM
Posts: 401 Norway
General 68
Norway
I now run Keislers new shifter and there is no buzzing noise coming from there. The vibration can be felt through the shifter handle thou. I chased a different vibration earlier and by that went through multiple pinion angle checks (3 degrees nose down - XHD springs), car up on jack stands, bell housing indexing, drive shaft check etc and found that the clutch and flywheel was not balanced correct. After balancing all was fine except the vibration in 4th gear.
I have tried running at same speeds, rpm's etc in other gears but can't get the vibration in other than 4th gear.
Every piece in brakes, wheels, suspension, steering and driveline were new or rebuilt a few years back and only have like 6-8K miles on it. I do run a poly trans mount like the ones Keisler used to supply and would like to try a rubber mount if I could find one that fits (it is the thick pad placed between the trans and the trans cross member - not a stock looking thing). Any idea where to find one? I guess that would make for an overall smoother ride. Still I think I am overlooking something as the 4th gear vibration smooths out after a couple of burnouts.
Like I said the trans shifts a little slow/hard without any grinding. Not sure but I have a feeling that it shifts better after some abuse when the vibration is gone. Anything related to tolerances and heat?
[Re: General 68]
#2060454
04/23/16 08:39 PM
04/23/16 08:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The Keisler kit uses the Ford transmission mount in poly, listed below from Summit Racing (perhaps your best vendor seeing your in Norway, and shipping/customs can be an issue)bolt pattern is all the same, only difference between the two, is the height you may require...both models are rubber OEM
[Re: General 68]
#2060456
04/23/16 08:44 PM
04/23/16 08:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
What fluid are you running? Mike
[Re: DAYCLONA]
#2060703
04/24/16 10:45 AM
04/24/16 10:45 AM
Posts: 19,491 north of coder
moparx
The Keisler kit uses the Ford transmission mount in poly, listed below from Summit Racing (perhaps your best vendor seeing your in Norway, and shipping/customs can be an issue)bolt pattern is all the same, only difference between the two, is the height you may require...both models are rubber OEM i'm glad you posted this, as i was thinking [now proved wrongly !] it was a gm mount for something like a pg, T350, etc. as most of those have a 3 bolt bottom mounting pattern and are not very tall. that mount is used on a ton of GM vehicles for years and years, and i just thought that would be used because of being widely available world wide. shows how much i know.
[Re: General 68]
#2062930
04/27/16 07:53 PM
04/27/16 07:53 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Not the real issue I guess but it is time to try a rubber trans mount anyways. Any ide of what height the two different Ford rubber mounts are? Summit doesn't list any height. The poly mount I have is about 2 1/2" high but is shimmed another 1/3". The 2784 is the Mustang mount which was used in most of the early Keisler kits, it's the taller of the two, plus it's a Tremec application for the Ford Mustang, depending on your driveline angle, you may still need to add a shim to increase the height
[Re: General 68]
#2063096
04/27/16 11:51 PM
04/27/16 11:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks Dayclona! Still hoping for more ideas around the vibration. Still curious as to what your driveline/transmission angle is in relation to the pinion angle, you stated 3 degrees down?, is this in relation to the driveshaft or transmission? Also who's driveshaft are running, Keisler supplied?, if so when (year) was it purchased? Mike
[Re: General 68]
#2063223
04/28/16 07:46 AM
04/28/16 07:46 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Pinion 3 degrees nose down in relation to the trans. Can,t recall the position in relation to the drive shaft. Driveshaft is custom made at a professional machine shop. Originally it was made for a shorter joke and was shortened an rebalanced (by the same shop). Vibration always was the same. 3 degrees down from the trans is OK, driveshaft angle should be 1.5 degrees ideally , no less than 1 degree, and no more than 2-3 degree deflection to the pinion or transmission angle, do you know what speed (RPM) the shaft was balanced too?, as most driveshaft shops only balance to 3500 RPM on average, Keisler did this also in the early stages of production, then around 2004/5 they started balancing to 10,000 RPM to better control the harmonics the shaft would see thru out it's RPM range
[Re: General 68]
#2114364
07/20/16 09:41 PM
07/20/16 09:41 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Update: Finally got time to work on the car. Installed an air/fuel gauge and got some weird readings. Checked the carburetor, Edelbrock 800 AVS, and found that the drivers side metering rod was not sliding free in the bore/jet. It would actually stick in the upper position! Seemes like the spring-like part that attaches the rod to the piston was bending the rod too hard to the side. Quick fix and guess what!: The vibration is gone! This issue made the motor vibrate a little and also caused the low end to be a little touchy impacting shifting feel. It seems to me that stepping on it would free the rod by causing an instant vacuumn change when letting off the throttle. I am quite shocked that this little issue would cause all kind of weird stuff! Guess who is happy! Glad to hear your issues got resolved! Mike
