strange flywheel/pressure plate wear #2058278
04/20/16 11:06 AM
04/20/16 11:06 AM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
Hey all. Right from the start my clutch was grabbing and difficult to engage smoothly. It even created a wheel-hop effect most of the time. When I pulled it all out, this is what I found-
You can see the heavy contact on literally half of the FW and PP. The disc did not look unevenly worn to me when removed. What do you think was the issue here? FW was resurfaced prior to installation.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058290
04/20/16 11:31 AM
04/20/16 11:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've seen spots like that from the metallic particles in the clutch disk rusting while sitting. Then when you run the engine they scuff like that because the rust has penetrated both the flywheel and pressure plate. It doesn't take long - I had that happen in about a month's time.
As for wearing on one side only it could be from uneven spring pressure but it could also be because only that side of the assembly rusted - more moisture in that side of the disk - although why, I can't imagine.
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058359
04/20/16 01:36 PM
04/20/16 01:36 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Can that rust be "burned off" with a couple of good launches, or is the only cure a new disc and resurfacing of the flywheel and the PP?
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058401
04/20/16 02:41 PM
04/20/16 02:41 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'd take a close look at the lever in the center of that wear. Bet you find a cracked lever or the pressure plate is cracked near it.
Angry white pureblood male
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058491
04/20/16 04:23 PM
04/20/16 04:23 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Not the first time I have seen a bad clutch assembly, whether rebuilt or new.. usually the pressure plate, but I have seen bad discs also..
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058545
04/20/16 05:59 PM
04/20/16 05:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is the clutch disc a race disc or street and strip? The race disc don't slip very much, just like thier designed to do shruggy
That being said it may have to much pressure plate pressure for your application also to drive nice on the street confused Good luck up Let us know what you find and do to fix it thumbs
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058595
04/20/16 07:56 PM
04/20/16 07:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The problem is only on one side of the plate. I would imagine it was a loose bolt or a problem with the PP.
A bolt broke on my PP several years ago. It caused similar symptoms and wear.
- Stu Harmon
Re: strange flywheel/pressure plate wear [Re: 426runner] #2058613
04/20/16 08:19 PM
04/20/16 08:19 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've seen a few cracked B&B pressure plates. That's why I mentioned it.
Usual symptoms include poor or no release. The hot spots on the pressure plate and flywheel tell which is suspect.
Re: strange flywheel/pressure plate wear [Re: ruderunner] #2058712
04/21/16 12:00 AM
04/21/16 12:00 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll agree with the others, Seems like a Pressure Plate issue, Myself, I'd replace the entire assembly, Flywheel included.
twocents beer
Re: strange flywheel/pressure plate wear [Re: TJP] #2058876
04/21/16 10:39 AM
04/21/16 10:39 AM
moparx Offline
moparx  Offline
twocents beer
a lot of times those hard [hot] spots on the flywheel can be blanchard ground to clean them up, but you don't really know how deep they go into the face of the flywheel. it will look good when done [ground], but if not removed entirely, will show up very quickly and the symptoms will return. i vote to replace the flywheel as well.
beer
Re: strange flywheel/pressure plate wear [Re: ruderunner] #2058964
04/21/16 01:14 PM
04/21/16 01:14 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes, right In the center of the spots is that lever. Could be anything mentioned, broken bolt, something cracked, bad/weak spring, pivot worn, heights not equal.
Re: strange flywheel/pressure plate wear [Re: 426runner] #2059294
04/21/16 09:47 PM
04/21/16 09:47 PM
Washington
madscientist Offline
Washington
Grind the flywheel. It is more than serviceable.
Normally when you see what you have, the finger height is off. What happens is as you push the levers down, one or possibly two of them are low to start with. The low finger or fingers do not let the disc get a gap from the flywheel.
See it all the time. It could also be a cracked cover or lever, but the result is the same. No need to replace a bunch of parts that are still more than good enough.
FWIW I never ever install a pressure plate without checking finger height. Should be done because humans make mistakes.
Re: strange flywheel/pressure plate wear [Re: moparx] #2059369
04/21/16 11:39 PM
04/21/16 11:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
twocents beer
beer
iagree twocents beer
Re: strange flywheel/pressure plate wear [Re: TJP] #2059858
04/22/16 06:27 PM
04/22/16 06:27 PM
Jacksonville, Fl
Jacksonville, Fl
The whole setup is being replaced. McLeod flywheel and dual disc package. Thanks for the great input. The flywheel I already sold... the PP is long gone. I blamed everything on it from the get-go.
Re: strange flywheel/pressure plate wear [Re: 426runner] #2060668
04/24/16 09:18 AM
04/24/16 09:18 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
You all missed the mark on this one. It's the basics of manual transmission. If you guys were real technical support people you all would have pink slips.
Before installing new parts the bell housing needs to be inspected for cracks and checked for run-out and squareness while bolted to the block and all fasteners torqued to spec.
Re: strange flywheel/pressure plate wear [Re: ThermoQuad] #2060718
04/24/16 11:28 AM
04/24/16 11:28 AM
moparx Offline
moparx  Offline
well, i'm not caring if i get a pink slip or not [i'm retired], but just how many transmission assemblies [clutch, pressure plate, bellhousings] were dialed in to be true at the original assembly plant ? now you are correct the parts in question need to be inspected for cracks, burrs on mounting surfaces, bolt torque, etc. but over the years i have ran into problems with clutch discs and flywheel/pressure plate chattering. in all but a couple instances, the only way the problem was fixed was replacement of clutch parts. no dial-in of the bell was done. i am very well aware of the importance of the dial in process and the need for parallelism of the mounting surfaces, but there are more cars out there running just fine without those checks being done than those that have. when replacing parts these days however, care must be taken to insure there are no burrs on mating surfaces, and things such as pressure plate fingers are even heights and throwout bearing flanges are not dinked up. aftermarket bells need special attention. back in my day, however, replacement parts were of better quality than those available today. the OP asked for advice and all i could give is what i have ran into in over 50+ years of playing with these things. i make no claims about me being the only "super genius" in the land and a person should not listen to anyone else's experiences or expertise. you have valid points, and one could and should check these things. but to have us all "fired" because we state our life experiences is just a little course. it just kinda rubbed me the wrong way. i apologize if i have offended you.
beer
Re: strange flywheel/pressure plate wear [Re: 426runner] #2060746
04/24/16 12:14 PM
04/24/16 12:14 PM
pa.
dan9 Offline
dan9  Offline
pa.
A friend of mine was describing the same issue he is having with a Chevy he is building. He has owned and built many cars in the 50 plus years that I have known him. America symptoms as yours. He has a Zoom clutch and pp. He had the flywheel turned at a reliable machine shop. He was planning on replacing everything. Is yours ok now?
Re: strange flywheel/pressure plate wear [Re: NANKET] #2060786
04/24/16 01:22 PM
04/24/16 01:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
OK pink slip, what are the last three words in my post above??? Thanks for your deception!
Re: strange flywheel/pressure plate wear [Re: ThermoQuad] #2060840
04/24/16 02:46 PM
04/24/16 02:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
While I don't discount the need to check components, torque to spec. etc. I am curious as to how a misaligned bell housing would result in that wear pattern. If it were that far out of center or parallelism there would be other issues IMO. whistling confused
Re: strange flywheel/pressure plate wear [Re: 426runner] #2060997
04/24/16 08:39 PM
04/24/16 08:39 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep, off center bell or not parallel would cause oodd wear ALL AROUND the flywheel. Just basic physics.
This is extremely localized wear.
