Re: DANA 3.54 vs. 4.10
[Re: BDW]
#205925
01/27/09 06:25 PM
01/27/09 06:25 PM
Posts: 4,785 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I dont know the difference in ET but the difference in acceleration will be phenominal. Highway driving will suck the enjoyment out of driving though. In my Challenger with 4.10s Id always bump the megashifter thinking I had another gear. (Engine buzzing like crazy @ 65mph in 3rd)
Keep old mopars alive.
[Re: 2boltmain]
#205927
01/27/09 08:37 PM
01/27/09 08:37 PM
i think a Passon Hemi overdrive trans will cure all of your problems with a 4.10.
[Re: Dodgem]
#205930
01/27/09 09:27 PM
01/27/09 09:27 PM
Posts: 4,748 Florida
BDW
Looks even more expensive
System Pricing Price Code RVs Trucks Cars Racing Install & Driveshaft RVs & Trucks A $ 2,795.00 $ 2,595.00 $ 750.00 B $ 2,895.00 $ 2,695.00 $ 750.00 C $ 2,995.00 $ 2,795.00 $ 750.00 D $ 3,195.00 $ 2,895.00 $ 850.00 E $ 3,295.00 $ 2,995.00 $ 850.00 F $ 3,395.00 $ 3,195.00 $ 850.00 G $ 3,595.00 $ 3,595.00 $ 900.00 H $ 4,995.00 $ 4,995.00 $ 1,800.00
[Re: BDW]
#205931
01/27/09 09:31 PM
01/27/09 09:31 PM
That's a $4k solution, I'll try the 4.10, then probably switch if it's too bad.
The last time I checked you could buy the gear set for $1700. + shipping. It will fit right in your existing 23 spline 833 Mopar 4 speed case. With labor and clutch disc change you should be able to do it for around $2500.
#205932
01/27/09 09:34 PM
01/27/09 09:34 PM
THREE TENTHS!!!!!! It better be good for more than that!!!!
It's been a looooooonnnnngggg time since I've strapped on a musclecar, but I remember "back in the day" that my heavy old '70RR with it's hundreds of pounds of tools in the back, etc, and I came across someone with 4x rear gear, the outcome (with my 3.54's) was not good. Not good at all
#205933
01/27/09 10:30 PM
01/27/09 10:30 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Alot of it will depend on the combo. I switched from 410's to 373's. I also gained 100 pounds(the car not me) and went exactly 1 tenth slower. That tenth acounts for the weight, but not the gear. A stocker big block with 3.54's in a ligher car, may slow down with 410's instead of pick up.
