Most stock SB balancers are 7.25... I am running
a Fluidamper on my 416(340 base) but if you are
running a internal balance then any SB zero balance
is what you need.. dont cheap out because a lot of
the cheaper ones will spin on the rubber joint.. a
cheaper SFI inst that pricey and will be better in
the long run.. on my 416 I only turn 7200 rpm which
to me is low rpm.. that Fluidamper is heavy.. on my
race engine I went ATI.. much lighter weight and I
have turned that one up to 9600 rpm
EDIT
If I recall... the tape that MP sells was for all
7.25 diameter balancers(that gave you a full 360*
on balancers that only had 10* indication on them
