Add on bed hooks #2058790
04/21/16 01:56 AM
04/21/16 01:56 AM
Sacramento, CA
E
ESP47 Offline OP
ESP47  Offline OP
E
Sacramento, CA
What are you guys using to tie down objects in the bed? I have a 75 D100 that's in good shape and I don't want to scratch the paint or add anything permanent by drilling into the bed. Do you guys have any suggestions as far as aftermarket hooks go for the 4 corners of the bed?
Re: Add on bed hooks [Re: ESP47] #2058879
04/21/16 10:46 AM
04/21/16 10:46 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
They make a few different styles of device that expand into the stake pockets so you can have anchors at those 6 points.
Re: Add on bed hooks [Re: ESP47] #2059552
04/22/16 10:27 AM
04/22/16 10:27 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I had ones like these cheapo $10 junkers.
I say had because I snapped one clean off the stud just the other day while using a smaller ratcheting tie down. Apparently these don't like to be pulled on too much so if you need something on the heavy duty side, stay away from these.
'71 Duster
'17 Ram 1500
Re: Add on bed hooks [Re: ESP47] #2059596
04/22/16 12:01 PM
04/22/16 12:01 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://www.amazon.com/dp/B001A0F8VA?psc=1
I use those on my late model Chevy and been good, and I have ratchet tied down a lot of pallets of stuff to them in the back.
