Re: crank rod piston balance Q&A #205876
01/28/09 11:42 AM
01/28/09 11:42 AM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
A while back I balanced a set of stock 400 rods, from heaviest to lightest there was a difference of 40 grams.
Re: crank rod piston balance Q&A #205877
01/28/09 04:51 PM
01/28/09 04:51 PM
I think I know the answer but must ask.A friend bought a crank from a vender and that vender is claiming that he balanced the crank. How can a crank get balanced without the rods,pistons etc??
it's done all the time. all you need is the weights from the other components. obviously, without those weights it's an exercise in futility at best.
Re: crank rod piston balance Q&A [Re: Kelob_pie] #205878
01/28/09 06:06 PM
01/28/09 06:06 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
40 grams thats amazing! I think superstock said it best about the "balanced" crank shaft w/o other speed parts
Well I hate to admit it but I ll check my weight between pistons, make sure they work together and go ahead and strap it together. The 1.5 point gain in compression and the ability to use my new heads is going to be worth the risk of beating the bearings out and having harmonics. Anybody deny me that? Besides, gearheads live in a world of broken parts!
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
