Transmission Neutral Switch #205805
01/27/09 01:04 PM
01/27/09 01:04 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
I just finished the engine transfer on my 68 charger with a 727 automatic and when i went to go start it she would only start in neutral and when ever it went into park i would get nothing. So is this my neutral safety switch or should i be looking somewhere else? Also i needed a new alternator and the auto zone gave me a replace they said was the correct one for the 440 and it fit and everything but there was a sticker on the side of it that said a on board computer would control how much it charged the battery, but it fit right up and seems to work, am i using the wrong thing or is it fine?
Thanks for any input and sorry about the length
Re: Transmission Neutral Switch [Re: 440_ci] #205806
01/27/09 01:15 PM
01/27/09 01:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Adjust your linkage a bit so it pushes it slightly more into park.
I would not sweat the starter!
Re: Transmission Neutral Switch [Re: Dodgem] #205807
01/27/09 01:19 PM
01/27/09 01:19 PM
Andrewh Offline
Andrewh  Offline
I agree. When you connected your shifter linkage to the transmission your shifter or the shifter in the transmission wasn't quite where you thought it was.
so you are not all the way in park.
Re: Transmission Neutral Switch [Re: Andrewh] #205808
01/27/09 01:27 PM
01/27/09 01:27 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Okay so the linkage that goes directly into the transmission or the part that connects right before the transmission? Also what are your thoughts on the alternator iam using and that onboard computer sticker?
Thanks Alot!
Re: Transmission Neutral Switch [Re: 440_ci] #205809
01/27/09 01:53 PM
01/27/09 01:53 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Alternator I'm not sure on that one. Is it a 3 wire, 2 wire or one wire???
Re: Transmission Neutral Switch [Re: 440_ci] #205810
01/27/09 01:54 PM
01/27/09 01:54 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
The only part of the linkage that is adjustable is the rod that attachs to the shift lever on the trans.
Re: Transmission Neutral Switch [Re: Dodgem] #205811
01/27/09 01:57 PM
01/27/09 01:57 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Its a 2 wire , the circle bolt and the one clip near the top.
Re: Transmission Neutral Switch [Re: 440_ci] #205812
01/27/09 02:02 PM
01/27/09 02:02 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As for your neutral switch,is it the one that is original to the transmission? There are two different one wire switches,each take a different internal cam to operate correctly.
Re: Transmission Neutral Switch [Re: 440_ci] #205813
01/27/09 02:13 PM
01/27/09 02:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would think they mean it's not like a chevy internally regulated but done by your regulator .
Do you have electronic regulator and ignition??
