Re: Holley 750 stumbles on acceleration?
[Re: chicagotim2003]
#2057670
04/19/16 03:37 PM
04/19/16 03:37 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
What's your timing at? Trans kicking down?
When it takes more than a sweet mullet to prove you rule at the trailer park..
#2057672
04/19/16 03:39 PM
04/19/16 03:39 PM
RapidRobert
I ain't a holley guy but iirc they want 15 tho clearance on that lever. I would just see how much squirt you have idling and at the RPM you would be at, at 25-45 MPH (you would not be under a load but it'd be a start). No vac leaks. I'm kinda WAG but that'd be where I'd start
#2057694
04/19/16 04:03 PM
04/19/16 04:03 PM
RapidRobert
I'm trying to think what is different after 45 MPH than 20-45. & it runs good after 45 or just so so? Vac leak keeps coming to mind. EDIT I reread & you rebuilt it, was it OK before as far as this issue goes other than needing rebuilding? If so I would confirm all vac lines are OK/base gasket correct/check bolts/screws for no loose ones then open the carb back up. if no on the Q, holler back
#2057711
04/19/16 04:19 PM
04/19/16 04:19 PM
Posts: 2,094 central texas
krautrock
central texas
that .015 clearance is when the throttle is fully open.
when your throttle is closed you want the pump lever adjusted so that there is no slack, you want a pump shot as soon as the throttle makes any movement.
if the stumble comes in when you are keeping the throttle steady then the pump shot isn't in play there.
did the kit you used to rebuild the carb give you the same power valve rating as you had before???
if you don't have a large cam then you can probably go up to atleast an 8.5PV...
#2057742
04/19/16 05:13 PM
04/19/16 05:13 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""It seems from 20 to 45 mph it stumbles"" ""After 45 it runs smooth and throttle response is better""
If it stumbles while cruising (not accel), and after 45mph the cruise is smooth, it sounds like your transition circuit (IFR's or IAB's) are lean. Then when it starts transitioning into the Main circuit, your Primary Jets/HSAB's are helping as they should. Try some smaller Idle Air Bleeds to see if that helps the 20 to 45mph stumble. This picture shows you which bleeds are the IAB's.
Note: See above response as to getting the timing/idle setup correctly first before tweaking the cruising tuneup.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#2057822
04/19/16 07:08 PM
04/19/16 07:08 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I have it adjusted at .015 at idle NOT wide open throttle. I will adjust and report back. The reason for the .015 @ WOT is so the acc pump doesn't top out and bind/bend the linkage. Two main reasons for stumble -not enough fuel -incorrect timing To avoid an over-rich carb, correct the timing first, then make carb changes.
