904 pump conversion #2057464
04/19/16 10:25 AM
04/19/16 10:25 AM
Canada
3
3forty Offline OP
3forty  Offline OP
Canada
What is involved to use the A500 flat type pump gears in a mid '70s 904 pump?
Re: 904 pump conversion [Re: 3forty] #2057710
04/19/16 04:19 PM
04/19/16 04:19 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Should just be installing the 93-04 pump gears which have flats in the place of the lugged style gears. At that point it's just having the correct converter - lockup/non-lockup, correct input spline count, etc. along with the pump drive with the flats. I've done quite a few with no issue.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 904 pump conversion [Re: 3forty] #2057773
04/19/16 06:12 PM
04/19/16 06:12 PM
Canada
3
3forty Offline OP
3forty  Offline OP
Canada
I thought you might have to use the front cover off an A500 pump.
Re: 904 pump conversion [Re: 3forty] #2057853
04/19/16 08:00 PM
04/19/16 08:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can not just swap the gears, they are bigger diameter.
