Page 5 of 6 1 2 3 4 5 6
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2056111
04/17/16 01:41 PM
04/17/16 01:41 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
This is the end game for Double Trouble - A tribute car to an old racer friend Ray Beraducci - who got me started and helped me learn - this was his old car which I bought and turned into the DoubleD - its long gone - Ray passed away a few years back - we talked about doing a clone of the original Hefty - I just wish Ray was still around to see it.
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2056362
04/17/16 08:33 PM
04/17/16 08:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Can't wait to see this one on the alignment rack and put that sweet smell of racing fuel in the shop devil
Gus beer
64 Plymouth Savoy
Dana 60
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2056427
04/17/16 10:37 PM
04/17/16 10:37 PM
Aurora, Oh.
max_maniac Offline OP
Aurora, Oh.
It will be a fun journey to the remaking of the HEFTYHEMI.
This year will be sorting out the Wedge and the car to make sure all is good and ready for the Hemi transplant and more then likely over next winter will be the complete transformation to the Hefty.
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2057276
04/18/16 11:54 PM
04/18/16 11:54 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Russ, sounds like the "Team" will be in Bowling Green?
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2057278
04/18/16 11:56 PM
04/18/16 11:56 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
up up
Re: Project Double Trouble - Max Maniac Two [Re: wyoming] #2057325
04/19/16 12:37 AM
04/19/16 12:37 AM
Aurora, Oh.
Aurora, Oh.
Glenn, it will only be me and the 63.
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2304852
05/15/17 01:42 PM
05/15/17 01:42 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Well here is an update on project double trouble – We got the car out last fall after a series of set-backs for a couple of passes and quickly realized we had the wrong converter and gear – we had used a 9” ATI we had on the parts shelf – it had nowhere near the stall we need and with a 4:10 gear it only compounded the problem the car was a mid-11 second ride with that combo – so over the winter we put in our spare an 8” ATI and a new 4;56 gear – took the car out to Quaker over the weekend and it definitely liked that combo with a 10.77 @125 with 1.45 sixty foot wheels up! - pretty much where I thought it would run with the factory cross-ram and 34 degrees timing. Not bad for a 3800+ lb whale with a full factory interior on cal tracks and 9” slicks. A little tuning will probably net a tenth or so – maybe add an INDY bathtub cross-ram somewhere down the line and that would put it solid and cover the 10.50 index. But this engine will be short lived in the car - the 572 HEMI is being built at BEST Machine and will replace the 512 sometime later this year – as it becomes a replica of the Hefty HEMI. But for now Russ will race the car at Bowling Green this weekend as the strictly business 63 is not ready yet.
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2371463
09/15/17 10:31 PM
09/15/17 10:31 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Time for an update - the car has been real consistent so far this year even with two different drivers. The 512 wedge has a factory cross ram and - likes to stay in the 10.65 - to 10.75 range with a MPH at 128 - the converter is not quite right for the car - but it works for now. Not bad for a 3800 lb car with a full interior - there is more ET in this combo - but its time to take it out and move on with Plan B - The HEMI ! The engine is almost complete - Best machine got the nod - and I am thrilled so far! It will be on the dyno soon.
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2371480
09/15/17 10:58 PM
09/15/17 10:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Can't wait to see it run.
Doug
Re: Project Double Trouble - Max Maniac Two [Re: dvw] #2371516
09/15/17 11:58 PM
09/15/17 11:58 PM
Aurora, Oh.
Aurora, Oh.
Doug
I can't wait either but - Dave said he is building a mild Hemi to stay in the 10 sec range shruggy
Yea right - whistling I have this feeling it's going to be cage time help
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2401344
11/10/17 12:26 PM
11/10/17 12:26 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Well the HEMI is Home and in the engine bay - Lots of work yet to go - new torque converter, headers to get coated - add a few bars to the roll bar to make it a cage - probably going to change the rear suspension to a ladder bar - and hopefully get the rest of the car painted before spring!
The HEMI made 870 HP at 6900 rpm and 740 ft-lbs at 5600 rpm with two box stock 800cfm eddies - I am more than happy with those numbers! Best Machine built a durable killer engine!
This car started as a budget build - that concept got lost somewhere along the way! But we are having some fun!
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2401371
11/10/17 01:17 PM
11/10/17 01:17 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Nice build. Close to mine. My 528' Hemi made 853@7100 & 691@5400 but mine is a 10.5:1 Pump gas street engine. My car will be mostly strip but will still street cruise it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Project Double Trouble - Max Maniac Two [Re: 6PKRTSE] #2401492
11/10/17 05:53 PM
11/10/17 05:53 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
WOW Dave,you ain`t fouling around !!!!!!
What would Cook say-----"now what"?
Awsome
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2401620
11/10/17 10:29 PM
11/10/17 10:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks awesome, can't wait to see the results. up
Re: Project Double Trouble - Max Maniac Two [Re: ProSport] #2401709
11/11/17 01:14 AM
11/11/17 01:14 AM
Aurora, Oh.
Aurora, Oh.
BUT ---- we never even got a chance to get the 512 Wedge tuned in yet???? Oh well it will make a good back up engine if nothing else. Wonder how long it will take Dave to change direction again - shruggy
It's all FUN and can't wait until next spring!!! drive
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2402943
11/13/17 11:55 AM
11/13/17 11:55 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You know an injector stack would look cool - but with electronic fuel injection - is that legal in FX??
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2402999
11/13/17 01:46 PM
11/13/17 01:46 PM
Aurora, Oh.
Aurora, Oh.
FUEL INJECTION Era-correct mechanical fuel injection permitted in FX classes only.
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2403006
11/13/17 01:55 PM
11/13/17 01:55 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I can hide the injectors - like I can hide the grid!
Re: Project Double Trouble - Max Maniac Two [Re: DoubleD] #2403129
11/13/17 05:36 PM
11/13/17 05:36 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
2018 is shaping up to be an interesting and fun year. The project is awesome and the build post has been very entertaining. Looking forward to rejoining friends for a safe and fun season.
Butch
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Project Double Trouble - Max Maniac Two [Re: max_maniac] #2480982
04/11/18 11:03 AM
04/11/18 11:03 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Well after a long winter its time to get the HEFTY HEMI to the track - I did not get the car painted as I wanted - But I figured adding some fiberglass parts will help with the weight - those are on order. So over next winter it will get painted - its true to the name at around 3900+ with driver.
