Are all A body headers created equal? #2056786
04/18/16 02:49 PM
04/18/16 02:49 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
So I bought a set of Hooker headers at a swap meet for my 74 Scamp. The previous owner stated they came off a 67 Barracuda and would fit my Scamp. I installed them and the idler arm hits one of the header tubes. Not just nicks it, I mean comes in full contact. Wondering I different manufacture of Headers would make a difference? Will ad that when I swapped the /6 for the 360 I also installed a new idler arm as well.
Thanks!
Re: Are all A body headers created equal? [Re: 74RR] #2056801
04/18/16 03:09 PM
04/18/16 03:09 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
the part number is the same for both im only guessing but if you raise the torsion bars will it clear?
Re: Are all A body headers created equal? [Re: 74RR] #2056807
04/18/16 03:13 PM
04/18/16 03:13 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
The k frame changed in around '72 or '73 with the spool type setup. With this, the idler arm, center ink, and pitman arm are different. The idler and pitman face down on the later style.
This might be the reason???
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Are all A body headers created equal? [Re: moparsquid] #2056816
04/18/16 03:16 PM
04/18/16 03:16 PM
74RR Offline OP
74RR  Offline OP
I have raised the bars. Now, dumb question. Once I drop the car to the ground with that make a difference with idler arm to header clearance? Like I said probably a dumb question.
Re: Are all A body headers created equal? [Re: 19swinger70] #2056817
04/18/16 03:18 PM
04/18/16 03:18 PM
74RR Offline OP
74RR  Offline OP
Yes, my idler and pitman arm all face downward.
Re: Are all A body headers created equal? [Re: 74RR] #2056867
04/18/16 03:55 PM
04/18/16 03:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ok, this is an engine swap, did you swap in a V8 k member or use conversion mounts, ala Schumacher?
Schumacher's mounts are two different heights and the taller of the two should be on the passenger side, which is the side you are having issues with.
If it's a factory V8 k member then look at the rubber bushing on the pass side mount and make sure it isn't collapsed.
Don't be the exception.
Re: Are all A body headers created equal? [Re: Supercuda] #2056951
04/18/16 05:14 PM
04/18/16 05:14 PM
74RR Offline OP
74RR  Offline OP
I did use the Schumacher kit. This is something I haven't looked into yet. Thank you!
Re: Are all A body headers created equal? [Re: 74RR] #2057021
04/18/16 06:29 PM
04/18/16 06:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Schumacher has the instructions on line if you don't have them.
http://www.engine-swaps.com/Pages/InstructionPages/73andUpS6-SB.html
Re: Are all A body headers created equal? [Re: Supercuda] #2057041
04/18/16 06:46 PM
04/18/16 06:46 PM
74RR Offline OP
74RR  Offline OP
Thank you! I'm certain I installed the mounts correctly,but stranger things have happened.
Re: Are all A body headers created equal? [Re: 74RR] #2057043
04/18/16 06:48 PM
04/18/16 06:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you cut down the driver's side as required? If not that wouold rotate the engine towards the pass side possibly being the issue?
Re: Are all A body headers created equal? [Re: Supercuda] #2057055
04/18/16 07:06 PM
04/18/16 07:06 PM
74RR Offline OP
74RR  Offline OP
Yes I did cut down the K member mount of the drivers side.
Re: Are all A body headers created equal? [Re: 74RR] #2057083
04/18/16 07:37 PM
04/18/16 07:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, shoot, I dunno.
Re: Are all A body headers created equal? [Re: Supercuda] #2057091
04/18/16 07:47 PM
04/18/16 07:47 PM
74RR Offline OP
74RR  Offline OP
Ya me neither. But I appreciate all your help!
Re: Are all A body headers created equal? [Re: 74RR] #2057099
04/18/16 07:55 PM
04/18/16 07:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Unless the header are not what is claimed. Did you look at the pictures of Hooker Headers at Summit and see if they match what you have?
Only other thing I can think of. They make a couple of different types that will bolt to the small block, but not fit the chassis.
Re: Are all A body headers created equal? [Re: Supercuda] #2057105
04/18/16 07:59 PM
04/18/16 07:59 PM
74RR Offline OP
74RR  Offline OP
Mmmmm,,,good idea! I have not done that but I will! Thanks!
