Re: Diff. between a '12 Ram 5.7 vs '09 Chall.5.7 ?
[Re: Cheatham]
#2056239
04/17/16 05:01 PM
04/17/16 05:01 PM
Posts: 4,255 Canada
WO23Coronet
Canada
You'd have to swap out the MDS lifters. I also think there subtle differences in a MDS cam and a non MDS cam (think I read it's in the ramps on the cylinders that shut off) but they spec out the same. I can't see how it would be to tough to use. Perfect time to stick in a 6.4 SRT cam Edit: I should expand on this more as the 09 engine is non MDS as its a 6 spd, the truck engine is MDS though, that's why you have to swap out MDS lifters
[Re: GoodysGotaCuda]
#2057131
04/18/16 08:45 PM
04/18/16 08:45 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Are either VVT engines? Both? I dont know, i do know the Ram has 395 horse and the 09 chally has 375 on the advertisements
#2057299
04/19/16 12:18 AM
04/19/16 12:18 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Are either VVT engines? Both? Every 09+ hemi is a VVT engine.
[Re: Twostick]
#2076501
05/19/16 02:24 PM
05/19/16 02:24 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
When did the quit MDS on 5.7's?
Kevin My 09 Challenger six speed had no MDS, I am not sure when the 6 speed received it but I am thinking 2011? Thank you Red
[Re: WO23Coronet]
#2076661
05/19/16 06:55 PM
05/19/16 06:55 PM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
You'd have to swap out the MDS lifters. I also think there subtle differences in a MDS cam and a non MDS cam (think I read it's in the ramps on the cylinders that shut off) but they spec out the same. I can't see how it would be to tough to use. Perfect time to stick in a 6.4 SRT cam Edit: I should expand on this more as the 09 engine is non MDS as its a 6 spd, the truck engine is MDS though, that's why you have to swap out MDS lifters Not sure if this is pertinant to this but I found the tops of the regular and mds lifters are different. So a new plastic lifter holder from a non-mds engine will be needed when swapping them out.
