ID these Hemi K frames #2055893
04/17/16 12:09 AM
04/17/16 12:09 AM
Iowa
ratroaster Offline OP
Iowa
Can anyone ID these Hemi K frames? Looks like the left side (drivers side) mounting is different.
Re: ID these Hemi K frames [Re: ratroaster] #2056042
04/17/16 11:05 AM
04/17/16 11:05 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Do you have a picture of the skid plates ?
The bottom one is 70 - 71 going by the swaybar mount holes , I can't see them on the top one? B or E ???
Mainstream Media is the new Pravda
Re: ID these Hemi K frames [Re: JohnRR] #2056120
04/17/16 01:05 PM
04/17/16 01:05 PM
Iowa
Iowa
I should have worded this different. I believe the bottom one is a Hemi E body K frame and the top one is a 63-70 B-body.
I did some research using the search function and many claimed the only difference between a 63-70 hemi B-body and 70-71 E-body/71 B-body hemi K frame is the steering box mounting angle.
It appears the top one has a different style motor mount bracket on the left drivers side without the slot in the mounting face.
Re: ID these Hemi K frames [Re: ratroaster] #2056175
04/17/16 02:16 PM
04/17/16 02:16 PM
AndyF Offline
AndyF  Offline
Double shear idler mount means they are '68 or newer. Can't really tell for sure without seeing the anti-sway bar mounting arrangment.
Re: ID these Hemi K frames [Re: AndyF] #2056195
04/17/16 02:48 PM
04/17/16 02:48 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
These are from a '68-'69 I sold cheap because it had been butchered for the later sway bar. I also had an NOS '70 (no pictures I could find) that had the rounded skid plate rather than the rectangular.
Re: ID these Hemi K frames [Re: ratroaster] #2056551
04/18/16 12:35 AM
04/18/16 12:35 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The K with that extra bolt is something I remember on an NOS E body K I got with my crate hemi m
Need to see skidplates and the undersides of both. There are many differences, almost all K's are one year only, especially with B bodies.
Re: ID these Hemi K frames [Re: ratroaster] #2264367
03/06/17 03:50 PM
03/06/17 03:50 PM
Challenger
O
Ole Bartholdy Offline
O
Challenger
The K with that extra bolt on an NOS E body K ,
Where are that Hole located ?
Re: ID these Hemi K frames [Re: Ole Bartholdy] #2264521
03/06/17 08:08 PM
03/06/17 08:08 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
This is an E-body with the rounded skid plate
Re: ID these Hemi K frames [Re: mccannix] #2264548
03/06/17 08:50 PM
03/06/17 08:50 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
top side E body
Re: ID these Hemi K frames [Re: Ole Bartholdy] #2264600
03/06/17 10:02 PM
03/06/17 10:02 PM
Iowa
Iowa
Here is the extra hole for hemi b-body's. B bodys have a different mount with an added fastener.
Re: ID these Hemi K frames [Re: ratroaster] #2264602
03/06/17 10:05 PM
03/06/17 10:05 PM
Iowa
Iowa
Whoops....
