Fuel pressure drops once engine warms up.
#2055824
04/16/16 11:43 PM
04/16/16 11:43 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Hey pals, maybe this is an easy one that you can help with. Trying to get the car ready for the trip to So Cal. The Charger runs fine but the fuel pressure reading is confusing me. When the car is cold and first started, the guage on the dual feed line reads a solid 7 lbs at idle. The clear filter is full and things all seem good. Once the engine warms up, the fuel pressure goes down. This has happened in the past, noteably during camshaft break in where the engine began to stumble. Once the pressure drops, the fuel filter also shows it: Fuel no longer fills it completely, it sometimes just pulses and bubbles in there. The pressure drops to zero sometimes.
The engine is a 440/493, MP 528 cam, 2" headers, 3" exhaust, Holley mechanical pump with less than 2500 miles on it. I have the A/F tuned with a wideband guage. ALL fuel line connections are secure. Gas tank and sender was new in 2003. The car runs fine when cruising but will stumble sometimes at WOT. I had a Carter pump on it once but it read 11 lbs at idle. I figured I'd try it sometime later when I had the time to integrate a regulator and a return line. I didn't have the Carter pump on the car long enough to see how it was with the car in use.
I don't know if this could be considered vaopr lock. The car runs a consistent 200 degrees. This happened before with another Holley pump but I didn't want to bash the brand. I'm probably going to try the Carter pump again just to see what happens with the engine up to temp.
Any suggestions on a decent adjustable fuel regulator with a return port? I don't know much about these setups but I was planning on using the 1/4" vent line for the return line. The fuel line is a 3/8". The 70 Charger has the 2 nipples on the fuel sender as well as 5 hoses that come off of the top of the tank, routed to an evap tube mounted to the RH side of the trunk floor near the wheel tub.
Re: Fuel pressure drops once engine warms up.
[Re: stumpy]
#2055872
04/17/16 12:49 AM
04/17/16 12:49 AM
RapidRobert
What Stump said, check for a vapor lock (heat) prob then plumb the pump inlet to a can of gas to elim or confirm a prob from there rearward (line dia too small/pinhole in line/pickup and sock restriction) then what is left is pump/line capacity up front. I like to T at the carb inlet & run it to a reg & then to a return line to the tank & use the reg to modulate the amt of return flow to the tank to control the psi and to keep a constant flow of fuel
[Re: Kern Dog]
#2055994
04/17/16 08:27 AM
04/17/16 08:27 AM
Posts: 5,777 ohio
ruderunner
ohio
Fuel tank not venting right? When it happens pop the gas cap and listen for a sucking sound. Fuel pressure will rise again too.
Saw a 97 Chevy van actually suck the tank in a couple inches due to a plugged vent.
Angry white pureblood male
[Re: Kern Dog]
#2056189
04/17/16 03:35 PM
04/17/16 03:35 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I could not make a Carter High Volume mechanical fuel pump work for the life of me. As soon as it heated up any it would start dropping in flow.
I don't give up easy but ended up dumping the mechanical fuel pump and went electric.
Talked to a lot of people about it including the manufacturer reps and most agreed its a common problem on high volume pumps.
Is this a high volume?
[Re: TJP]
#2056326
04/17/16 07:32 PM
04/17/16 07:32 PM
Kern Dog
Granite Bay CA
The engine has Edelbrock heads with no crossover. We do have ethanol in the fuel, the pump sticker states "Up to 10% Ethanol."
I used the infrared thermometer to see what temps I was getting. Just idling in my 75 degree shop, engine at 195-200, the carb primary bowl was at 135, the fuel line was between 110 to 140. Fuel pressure started to drop to 4, the filter started to empty out a little. I went for a drive, 20-30 minutes or so. When I got on the throttle, it ran great then started to drop off as I went to 2nd gear. This is probably where I am running out of fuel. Back at home, I checked temps again. The fuel line had jumped to the mid 160s, the carb primary bowl was at 135-140. The filter was at 125. I prefer to know why something is failing rather than to just replace it. I'm sure an electric pump, regulator and return line would solve this.
[Re: Kern Dog]
#2056373
04/17/16 08:54 PM
04/17/16 08:54 PM
Posts: 5,777 ohio
ruderunner
ohio
Another option, junk in the tank plugging the pickup tube?
Had that happen to my Jeep.
[Re: Kern Dog]
#2056578
04/18/16 02:49 AM
04/18/16 02:49 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
check the fuel pump push rod, it could be worn down, seems to be a common problem.
[Re: Kern Dog]
#2057220
04/18/16 10:47 PM
04/18/16 10:47 PM
Kern Dog
Granite Bay CA
Thanks. I did check the pushrod for the pump when I swapped camshafts last May. This issue has happened before and is worse with warmer weather when I take the throttle beyond a casual type drive. I am now looking at revamping the fuel system with a bypass type regulator. This Holley unit is preset to 7 psi, right where I should be. http://www.summitracing.com/parts/hly-12-803bp/overview/I just checked the google search function here to see how others plumbed their setups. I am thinking of running the Carter pump with the next setup. Check out how Mallory shows the routing of their bypass regulator: http://www.jegs.com/InstallationInstructions/600/650/650-4309.pdfIn 3A. I could simply attach the regulator behind the feed line to the secondary carburetor bowl and plumb the return line toward the firewall and down. In 3B, I could totally reroute the output/pressure side of the fuel line and run everything back toward the firewall away from engine heat and obstacles. My next question is this: Since I already plan to integrate a means to keep the fuel in a constant loop by way of the return line, would that be enough to reduce the fuel temps? I'm unsure of what temperature the fuel starts to boil but it seems that the return type setup should make some difference. I ask because the 3A method would be the easiest. I don't want to spend the time and then miss out on the benefits.
[Re: Kern Dog]
#2057400
04/19/16 02:24 AM
04/19/16 02:24 AM
CSK
Pattison Texas
this is the one I used, it is for a mechanical fuel pump, it has a jet bleed, I have a 3/8 supply & 3/8 return, I also wrapped all my lines. With the ac running & 107 outside temp I no longer have any heat related fuel problems. link to bypass regulator the Holley reg that you posted says this in the part description Notes: Cannot be used with mechanical fuel pumps.
