MSD digital 6 with factory distributor #2055737
04/16/16 08:54 PM
04/16/16 08:54 PM
Champion City
The Sphinx Offline OP
Champion City
I cant get my car to fire. I got the red LED light on, I get spark from the coil when I jumper the green and violet wires. Its like the box isnt getting a signal from the pick up in the distributor. I tried two working ones, one factory and one Mopar performance. Do I need to use an MSD distributor? I triple checked the wiring and the grounds.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2055749
04/16/16 09:18 PM
04/16/16 09:18 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
No, you don't need an MSD dist. You should be using the mag pickup lead (purple/green) wired to the dist pickup wires. (Box white wire not used)
You false triggered box by jumpering, and it worked, so box and coil are good.
If you have purple and green switched, it just retards timing, won't hurt anything.
Good Luck
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2055793
04/16/16 10:56 PM
04/16/16 10:56 PM
Champion City
Champion City
I am using the green and violet. Green to the black and violet to the orange wires to the distributor. No spark to the plugs
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2055798
04/16/16 11:02 PM
04/16/16 11:02 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
check the gap on the pickup coil?
Tony
70 AARCuda Vitamin C
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2055813
04/16/16 11:29 PM
04/16/16 11:29 PM
Champion City
Champion City
How much gap is there supposed to be?
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2055821
04/16/16 11:37 PM
04/16/16 11:37 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got mine set at 8 thous.been workin good many years.
Re: MSD digital 6 with factory distributor [Re: bonefish] #2055915
04/17/16 01:24 AM
04/17/16 01:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
.008 is spec... if it sparks jumping the box side of the
dist then your pick up is bad(if your gap is even in the
ball park)
EDIT
Make sure the carbon ball is in the center of the
cap and you have the rotor in there(been there)
wave
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056013
04/17/16 10:37 AM
04/17/16 10:37 AM
Champion City
Champion City
I'll check the gap. I just pulled the distributor out of a perfectly running car with an orange box ignition.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056059
04/17/16 12:27 PM
04/17/16 12:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was this car running before... or is this a new
build.. do you have both the run and crank wires
jumped together out of the ignition switch so it
has power during cranking and run
wave
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056089
04/17/16 01:13 PM
04/17/16 01:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Have you tried to start it by jumpering the starter relay?
Re: MSD digital 6 with factory distributor [Re: justinp61] #2056108
04/17/16 01:38 PM
04/17/16 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a good way to test the ignition switch to
see if both wires are connected together.. since
its in the run position
wave
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056129
04/17/16 02:19 PM
04/17/16 02:19 PM
Champion City
Champion City
Switch is good, 12v incomming is good, 12v(thick) red is good. It acts like im not signaling thru the distributor pick up.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056213
04/17/16 04:22 PM
04/17/16 04:22 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
spark at the coil?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056235
04/17/16 04:55 PM
04/17/16 04:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the test you did(jumping the box side of the
dist) thats what the test says also... I just went
through this last week.. but when I jumped the box
side it had a spark at the coil lead just 1 time
then nothing.. my coil was shot... after changing
the coil.. it runs better than it ever has
wave
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056247
04/17/16 05:27 PM
04/17/16 05:27 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I would just double check that the keyed 12 volts to the MSD stays hot while the engine is cranking...
Re: MSD digital 6 with factory distributor [Re: DARTH V8Я] #2056253
04/17/16 05:38 PM
04/17/16 05:38 PM
Champion City
Champion City
Originally Posted By DARTH V8R
spark at the coil?
Only when I jumper the violet and green wires from the box side.
Re: MSD digital 6 with factory distributor [Re: Forest] #2056255
04/17/16 05:39 PM
04/17/16 05:39 PM
Champion City
Champion City
I did, 12v when I'm cranking
Re: MSD digital 6 with factory distributor [Re: MR_P_BODY] #2056260
04/17/16 05:42 PM
04/17/16 05:42 PM
Champion City
Champion City
wave
I swapped out a blaster ss and tried blaster 2, no luck. I went through the troubleshooting guide that came with it and also their website. I ohmed out the distributor and got .287 on the 2k scale.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056274
04/17/16 06:09 PM
04/17/16 06:09 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Hmmm. Seems like you checked everything. Box is probably done.
Re: MSD digital 6 with factory distributor [Re: The Sphinx] #2056276
04/17/16 06:11 PM
04/17/16 06:11 PM
Champion City
Champion City
Brand new box
