Tri-Castle Nuts #2050727
04/10/16 12:23 AM
04/10/16 12:23 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Who sells Tri-Castle nuts for ball joints? I can find them for tie rods but can't seem to locate them for the ball joints.
Re: Tri-Castle Nuts [Re: 340cpe] #2050738
04/10/16 12:45 AM
04/10/16 12:45 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Roger Gibson and Frank Badalson has them.
Re: Tri-Castle Nuts [Re: 340cpe] #2050744
04/10/16 01:05 AM
04/10/16 01:05 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You my friend!!
Re: Tri-Castle Nuts [Re: 340cpe] #2050821
04/10/16 03:06 AM
04/10/16 03:06 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Many sellers of fasteners, including Frank, are buying from amkproducts.com. See page 46 here:
http://www.amkproducts.com/Catalog_PDF/39-55.pdf
AMK's minimum order is $30, and they offer only 1/2", not 7/16" (upper ball joints*) nor 9/16" (lower ball joints and idler arm*). *These apply to A bodies - no sure about other bodies.
Re: Tri-Castle Nuts [Re: kentj340] #2050916
04/10/16 11:27 AM
04/10/16 11:27 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
That is what I am finding. I can not locate the larger nuts. Frank does list a set but no description of what is in it. I will have to call. Also the car is a 71 b-body.
Re: Tri-Castle Nuts [Re: 340cpe] #2051554
04/11/16 01:15 AM
04/11/16 01:15 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
You can make 7/16" and 9/16" Mopar nuts out of generic castle nuts by grinding or filing off the unwanted parts. Avoid zinc plated generic nuts, since the Mopars are phosphated.
Mopar tri-castle nuts are fully forged, while generic castle nuts are typically sawn or machined on top. You'll need to make the sawn or machined parts look forged and re-phosphate your finished nuts or otherwise disguise the resulting bare metal portions.
Re: Tri-Castle Nuts [Re: kentj340] #2051637
04/11/16 04:27 AM
04/11/16 04:27 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
That would be too much like using your head.
Being that this is Moparts we need to first re-invent the wheel and then determine what we need to pay to air up the tires. pity
Mo' Farts
Moderated by "tbagger".
Re: Tri-Castle Nuts [Re: 340cpe] #2052321
04/11/16 11:26 PM
04/11/16 11:26 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Or you could make a trip to the boneyard and find suitable nuts...
Re: Tri-Castle Nuts [Re: screamindriver] #2052553
04/12/16 02:55 AM
04/12/16 02:55 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted By screamindriver
a trip to the boneyard...
Around here your chances of finding any Mopar from the 60s or early 70s in a boneyard are about as good as winning the lottery.
If anybody is interested in Bricklins, I know where there are 2 of those. Maybe they have tri-castle nuts?
Re: Tri-Castle Nuts [Re: kentj340] #2052814
04/12/16 03:05 PM
04/12/16 03:05 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
here you go....click here- Linky They have the lower ball joint hardware too.
Re: Tri-Castle Nuts [Re: ratroaster] #2053385
04/13/16 03:05 AM
04/13/16 03:05 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
That Linky may be showing 1/2" nuts, not sure as they aren't ID'd.
Megaparts has the lower ball joint hardware, but the nuts aren't hex tri-slots - they are hex 6-slots. Better than nothing.
Re: Tri-Castle Nuts [Re: kentj340] #2053660
04/13/16 02:28 PM
04/13/16 02:28 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
How many ya want?
Got a container full of castle nuts, that probably weighs 30 pounds, after taking suspensions apart at the Pick-N-Pull wrecking yards, for decades.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Tri-Castle Nuts [Re: hemi71x] #2053759
04/13/16 05:10 PM
04/13/16 05:10 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Yearone sells a set....not much description though. link below..
castle nut set
Re: Tri-Castle Nuts [Re: 340cpe] #2054696
04/15/16 12:35 AM
04/15/16 12:35 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Yes mega has the 1/2" nuts (tie rods) year one appears to have the full set with the larger nuts but a bit pricey and if I called they are probably on back order!!! LOL
Re: Tri-Castle Nuts [Re: 340cpe] #2054955
04/15/16 02:29 PM
04/15/16 02:29 PM
Canada
Maxwellwedge Offline
Canada
Franks are a complete set and include the cotter pins
Re: Tri-Castle Nuts [Re: Maxwellwedge] #2055281
04/16/16 12:01 AM
04/16/16 12:01 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank you sir I will give them a call
