Re: Tri-Castle Nuts
[Re: 340cpe]
#2050744
04/10/16 01:05 AM
04/10/16 01:05 AM
Posts: 647 Pa.
340cpe
Pa.
Re: Tri-Castle Nuts
[Re: 340cpe]
#2050821
04/10/16 03:06 AM
04/10/16 03:06 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Many sellers of fasteners, including Frank, are buying from amkproducts.com. See page 46 here: http://www.amkproducts.com/Catalog_PDF/39-55.pdfAMK's minimum order is $30, and they offer only 1/2", not 7/16" (upper ball joints*) nor 9/16" (lower ball joints and idler arm*). *These apply to A bodies - no sure about other bodies.
Re: Tri-Castle Nuts
[Re: 340cpe]
#2051554
04/11/16 01:15 AM
04/11/16 01:15 AM
kentj340
Cut and Shoot, TX
You can make 7/16" and 9/16" Mopar nuts out of generic castle nuts by grinding or filing off the unwanted parts. Avoid zinc plated generic nuts, since the Mopars are phosphated.
Mopar tri-castle nuts are fully forged, while generic castle nuts are typically sawn or machined on top. You'll need to make the sawn or machined parts look forged and re-phosphate your finished nuts or otherwise disguise the resulting bare metal portions.
Re: Tri-Castle Nuts
[Re: kentj340]
#2051637
04/11/16 04:27 AM
04/11/16 04:27 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Mopar tri-castle nuts are fully forged, while generic castle nuts are typically sawn or machined on top. You'll need to make the sawn or machined parts look forged and re-phosphate your finished nuts or otherwise disguise the resulting bare metal portions. That would be too much like using your head. Being that this is Moparts we need to first re-invent the wheel and then determine what we need to pay to air up the tires.
Mo' Farts
Moderated by "tbagger".
Re: Tri-Castle Nuts
[Re: screamindriver]
#2052553
04/12/16 02:55 AM
04/12/16 02:55 AM
kentj340
Cut and Shoot, TX
a trip to the boneyard... Around here your chances of finding any Mopar from the 60s or early 70s in a boneyard are about as good as winning the lottery. If anybody is interested in Bricklins, I know where there are 2 of those. Maybe they have tri-castle nuts?
Re: Tri-Castle Nuts
[Re: kentj340]
#2052814
04/12/16 03:05 PM
04/12/16 03:05 PM
Posts: 318 Iowa
ratroaster
Iowa
here you go....click here- Linky They have the lower ball joint hardware too.
Re: Tri-Castle Nuts
[Re: ratroaster]
#2053385
04/13/16 03:05 AM
04/13/16 03:05 AM
kentj340
Cut and Shoot, TX
here you go....click here- Linky They have the lower ball joint hardware too. That Linky may be showing 1/2" nuts, not sure as they aren't ID'd. Megaparts has the lower ball joint hardware, but the nuts aren't hex tri-slots - they are hex 6-slots. Better than nothing.
Re: Tri-Castle Nuts
[Re: 340cpe]
#2054955
04/15/16 02:29 PM
04/15/16 02:29 PM
Posts: 56 Canada
Maxwellwedge
Canada
That is what I am finding. I can not locate the larger nuts. Frank does list a set but no description of what is in it. I will have to call. Also the car is a 71 b-body. Franks are a complete set and include the cotter pins
