torque convertor: 727
#2054870
04/15/16 11:42 AM
04/15/16 11:42 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Friend posed a question and I was sort-of-puzzled.
Will the torque converter for a small block 727 fit into a big block 727? It is my understanding the input shaft on the tranny is the same, after all, isn't the basic difference between a small black 727 and a big block 727 the case?
If that's the case, then he would just have to have the appropriate flexplate for his application.. no?
Thanks in advance...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: torque convertor: 727
[Re: hemi68charger]
#2054880
04/15/16 11:52 AM
04/15/16 11:52 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I believe you're correct, although the year identity still matters on some older stuff.
[Re: hemi68charger]
#2054902
04/15/16 12:37 PM
04/15/16 12:37 PM
Posts: 416 Georgia
KingTuna
Georgia
66 and back had a lower spline count (18 i think) and 67 up had a 23 spline count. Don't quote me on those numbers, but its close. So yes, he could use the converter as long as he uses the correct flexplate or weights on the converter.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
[Re: KingTuna]
#2054904
04/15/16 12:42 PM
04/15/16 12:42 PM
hemi68charger
Houston, Tx
66 and back had a lower spline count (18 i think) and 67 up had a 23 spline count. Don't quote me on those numbers, but its close. So yes, he could use the converter as long as he uses the correct flexplate or weights on the converter. Thanks... 1 off.. They are 24 spline..
[Re: hemi68charger]
#2055013
04/15/16 04:13 PM
04/15/16 04:13 PM
Posts: 6,710 KY
65pacecar
KY
66 and back had a lower spline count (18 i think) and 67 up had a 23 spline count. Don't quote me on those numbers, but its close. So yes, he could use the converter as long as he uses the correct flexplate or weights on the converter. Thanks... 1 off.. They are 24 spline.. .....And 19 Spline (getting tough to find, and expensive)
