manual truck bellhousing, big block #2054939
04/15/16 02:04 PM
04/15/16 02:04 PM
Finally a HUSKER again
Moparnut426 Offline OP
Does anyone know off the top of their heads what a bolt pattern for a manual trany bellhousing in a truck is? Is that a Borg and Warner 4 speed, or a New Process?
cant remember
Re: manual truck bellhousing, big block [Re: Moparnut426] #2054954
04/15/16 02:26 PM
04/15/16 02:26 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
they were all NP435's I do believe from 62 to 93 I think
Re: manual truck bellhousing, big block [Re: CTD5.9] #2056581
04/18/16 02:56 AM
04/18/16 02:56 AM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
All the ones I've seen had 2 bolt patterns. 435 was one, I assume that the car 3 speed or 4 speed was the other pattern.
Re: manual truck bellhousing, big block [Re: Moparnut426] #2056644
04/18/16 10:14 AM
04/18/16 10:14 AM
I just see American powertrain is selling one with multi square patterns on it and was curious if that one was the same.
Re: manual truck bellhousing, big block [Re: Moparnut426] #2057070
04/18/16 07:24 PM
04/18/16 07:24 PM
Cruising!
Q
QuickDodge Online content
QuickDodge  Online Content
Q
Cruising!
I do not know about the Bellhousing you mentioned. Can you post a link to it?
Regarding factory bellhousings, there were also so a few big block to 833 OD transmission bellhousings. I think the overdrive was only available for a short time behind the 400 engine.
Re: manual truck bellhousing, big block [Re: Moparnut426] #2057160
04/18/16 09:14 PM
04/18/16 09:14 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
The bell in my truck is a #272 which is the NP435 bolt pattern, 5.125" retainer opening.
There is a #670 bellhousing out there that came behind big block trucks in 77'-78'. There were no factory BB truck/833 combos to my knowledge but for whatever reason the bells were drilled for both the 833 and NP435.
I search daily for a #670 BB dual bolt pattern bellhousing. Not many out there.
Was wondering the same thing about the American Powertrain bell. If you use that I guess you are using a hydraulic clutch setup?
'71 Duster
'17 Ram 1500
