Hemi rotating assemblyl #2052842
04/12/16 03:29 PM
04/12/16 03:29 PM
Everywhere
Lost in life Offline OP
Everywhere
Just picked up a 4.5 bore Gen 2 hemi block. I want to build a 572 street motor for a cuda. What would be the most cost effective setup and where would I access same? I don't need the best of the best as the car will never see strip use. Planning on using mopar performance aluminum heads/rocker assembly and would like a compression of 10.5 or so. Suggestions for completing my long block would be appreciated. Thanks.
Re: Hemi rotating assemblyl [Re: Lost in life] #2052962
04/12/16 06:44 PM
04/12/16 06:44 PM
AndyF Offline
AndyF  Offline
Not sure if you'll be able to find a stroker kit or not but it isn't too hard to build your own. A 572 requires a 4.500 stroke crankshaft which you can get from SCAT, Callies, Molnar, etc. If it was me I'd use the Chevy 2.200 rod journals and then use a 7.100 long connecting rod. Then you just need pistons but those shouldn't be too hard to find. Diamond, JE, Ross, Wiseco, etc. can take care of you.
Re: Hemi rotating assemblyl [Re: Lost in life] #2052971
04/12/16 07:04 PM
04/12/16 07:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Use a shorter rod, then the pin won't be in oil ring.
Re: Hemi rotating assemblyl [Re: cudaman1969] #2053117
04/12/16 10:10 PM
04/12/16 10:10 PM
I'm almost sure the oil rings won't be in the wrist pin scope work I would call the piston maker you want to buy from and ask them about the wrist pin location with your stroke and the 7.100 long rods thumbs The lomger the rods the lighter the pistons can be thumbs
Re: Hemi rotating assemblyl [Re: Cab_Burge] #2053290
04/13/16 12:46 AM
04/13/16 12:46 AM
Everywhere
Everywhere
Thanks guys for the replies. I obviously need to learn more before bringing out the checkbook. Appreciate your knowledge.
Re: Hemi rotating assemblyl [Re: Lost in life] #2053339
04/13/16 01:39 AM
04/13/16 01:39 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have Eagle 4.5 crank with 2.2 rod journals , eagle 7.1 rods and Diamond 10.5 pistons in my 572 . Hemi's normally use a 8 bolt crank. Most distributors have all the items you need.
Re: Hemi rotating assemblyl [Re: AndyF] #2053347
04/13/16 01:57 AM
04/13/16 01:57 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
If you want to use an internal oil pickup you will need to use the 2.200 size rod journals.
As far as the Mopar Performance aluminum heads and valve gear, my M/Perf Edelbrock casting aluminum Hemi heads the springs went from 140 lbs of seat pressure down to 110 lbs of seat pressure in about 900 miles. Junk!
Re: Hemi rotating assemblyl [Re: Lost in life] #2053466
04/13/16 09:23 AM
04/13/16 09:23 AM
Everywhere
Everywhere
Thanks for the replies. So for my own understanding, what is involved in an external oil pickup? Also what reasonably priced head/rocker combination would you recommend if not for the mopar head assemblies? Appreciate it.
Re: Hemi rotating assemblyl [Re: Lost in life] #2053483
04/13/16 09:53 AM
04/13/16 09:53 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you're starting from scratch on buying parts I'd say use the 2.200 size rod journals and eliminate the need for the external oil pick-up completely.
If I would have known, I would have. twocents
It really depends on which block you start with on the external oiling system.
If it's a Mopar Performance/World block that has the AN boss on the front of the number 1 cylinder it's not too bad.
You basically need a pan mount swinging or fixed pick-up and a line to run it to the AN boss. You can use any normal style oil pump.
Mine uses a regular Street Hemi oil pan with the swinging pick-up.
How mine looked before paint.
Without the AN boss you need a pump that uses an external oil feed line, which can run into engine mount clearance problems if you run factory style mounts.
As far as the heads, if you replace the installed Mopar valve springs the Mopar Perf heads would probably be fine.
Stage V heads might be a better option. shruggy
Re: Hemi rotating assemblyl [Re: Lost in life] #2053573
04/13/16 12:21 PM
04/13/16 12:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You don't need knowledge. That's what Ray Barton is for. All you need is a phone.
2011 Drag Pak Challenger
Re: Hemi rotating assemblyl [Re: Cab_Burge] #2053664
04/13/16 02:39 PM
04/13/16 02:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine are 3/16 into the oil ring, have to have a ring support. This is with a 7.045 rod.
Re: Hemi rotating assemblyl [Re: Lost in life] #2053749
04/13/16 04:52 PM
04/13/16 04:52 PM
rowin4 Offline
rowin4  Offline
I did and would again call or e-mail Tim At FHO [for Hemi's only] for information about your build and what he can do for you.
Re: Hemi rotating assemblyl [Re: cudaman1969] #2053769
04/13/16 05:38 PM
04/13/16 05:38 PM
Which size wrist pin did you use, .990,1.040 or 1.07? Do you know how much your block deck has been cut? It has been a long while since I last assembled a 4.500 stroke 426 type Hemi motor so I may be not remebering correctly on the wrist pin location confused blush
Re: Hemi rotating assemblyl [Re: Cab_Burge] #2053784
04/13/16 06:26 PM
04/13/16 06:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Down .130 , 1.03 pin, 2.2 journal. A little wiggle room between crank and piston.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054193
04/14/16 12:01 PM
04/14/16 12:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I have had a few 572's (4.50" x 4.50"). All with Diamond pistons. Two with 7.1" rods and .990 pins (2.20" rods). Neither had the pin in the oil ring. I had one for heavy nitrous once that had thicker domes and the rings moved down. It had the pin in the oil ring.
Re: Hemi rotating assemblyl [Re: rickseeman] #2054258
04/14/16 01:53 PM
04/14/16 01:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Hemi or RB? Hemi valve relief dictates lower ring pack.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054336
04/14/16 04:18 PM
04/14/16 04:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Hemi. I will try to post a pic tonight of the last set.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054471
04/14/16 07:23 PM
04/14/16 07:23 PM
Everywhere
Everywhere
Hmmmm.. Maybe I would just be better off going with a 4.25 stroke I think that would give me a 528 with the 4.5 bore correct? Might be a whole bunch simpler for this newbie. Thanks for the replies.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054498
04/14/16 08:07 PM
04/14/16 08:07 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe 540 with 4.25 528 with 4.15
Re: Hemi rotating assemblyl [Re: Lost in life] #2054628
04/14/16 10:52 PM
04/14/16 10:52 PM
Everywhere
Everywhere
Ok. Didn't do the math. Thanks.
