Re: 1972 Charger SE Project by CDN72SE
[Re: CDN72SE]
#2054408
04/14/16 06:36 PM
04/14/16 06:36 PM
Posts: 428 Oakville, Ontario, Canada
CDN72SE
Interior shot, some pin holes on the drivers side floor, not bad at all, also my AMD front and rear valences sitting inside. Have to figure how to treat the corner part that has had some rust damage near the bottom of the window. Blasting cleaned this area up better than I did. The three tape references say it all, not bad.
[Re: CDN72SE]
#2054410
04/14/16 06:37 PM
04/14/16 06:37 PM
CDN72SE
The repairs have started! Common rust area, will be fixed right, passenger side lower windshield. Area previously stripped: [/url] The extent to any cowl damage, just some pinholes, again on the passengers side: [/url] Passenger fender was a little thin, needed a fix:
[Re: CDN72SE]
#2054414
04/14/16 06:38 PM
04/14/16 06:38 PM
CDN72SE
Been wondering what was behind this rocker panel. Time to cut it out: So this is what we have: Cleaned up and primed: Template made for new hand crafted part: The new piece with 20 gauge metal:
[Re: CDN72SE]
#2054432
04/14/16 06:43 PM
04/14/16 06:43 PM
CDN72SE
Turning my attention to the gauge cluster, my original had the clock and cut-out for some 80's cassette deck I had in there. Installed a new tachometer from Charger Specialties in place of the clock, also changed the lens to one without the hole for the clock thingy. Next I used a silver craft paint pen to go around the edges to make things look better. Put back together: Also went over the surrounding and the Charger SE emblem with the same pen. Since I had the pen out I did the dash vent as well.
