Re: 6.86" rod length in an RB wedge
[Re: AndyF]
#2053945
04/13/16 11:04 PM
04/13/16 11:04 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
Yeah I did a long rod 400 motor a few years back. Worked great. But the Mopar rods aren't very popular anymore, most everyone has switched over to the 2.200 rod journal since the rods are cheaper and there are more bearing choices. I have access to a set of good hemi aluminum rods and I was looking at my options. I might also have a line on a good 4.15 stroke crank, not sure on that yet.
[Re: camdog440]
#2054104
04/14/16 07:04 AM
04/14/16 07:04 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you go with the 6.86 rod, will it have a .990 pin in them? That leaves options open if you ever hurt it. If you end up with a Mopar pin size, there won't be any shelf stock parts to fix it most likely, and that means waiting for custom parts. If this is a moderate performance build, and savings is substantial, I would go for it. Not much in savings on parts, I would opt for a BBC rod/stroker combo.
[Re: AndyF]
#2054409
04/14/16 06:36 PM
04/14/16 06:36 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Yeah I did a long rod 400 motor a few years back. Worked great. But the Mopar rods aren't very popular anymore, most everyone has switched over to the 2.200 rod journal since the rods are cheaper and there are more bearing choices. Andy wasn't that rod the 6.965 manley sportsmaster rod ?
[Re: camdog440]
#2054415
04/14/16 06:38 PM
04/14/16 06:38 PM
JohnRR
U.S.S.A.
Yeah I did a long rod 400 motor a few years back. Worked great. But the Mopar rods aren't very popular anymore, most everyone has switched over to the 2.200 rod journal since the rods are cheaper and there are more bearing choices. I have access to a set of good hemi aluminum rods and I was looking at my options. I might also have a line on a good 4.15 stroke crank, not sure on that yet. Are they USED ??? if so PASS .... the 6.860 rod is only good if you are trying to reuse a set of low compression smogger pistons ... Hemi rods have different pin size that stad wedge rods . what pin size are the rods ?
[Re: JohnRR]
#2054485
04/14/16 07:49 PM
04/14/16 07:49 PM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
Yeah I did a long rod 400 motor a few years back. Worked great. But the Mopar rods aren't very popular anymore, most everyone has switched over to the 2.200 rod journal since the rods are cheaper and there are more bearing choices. I have access to a set of good hemi aluminum rods and I was looking at my options. I might also have a line on a good 4.15 stroke crank, not sure on that yet. Are they USED ??? if so PASS .... the 6.860 rod is only good if you are trying to reuse a set of low compression smogger pistons ... Hemi rods have different pin size that stad wedge rods . what pin size are the rods ? Rods can be bored( honed)out to the size you need, BM, all, said very easy to do on aluminum, the aftermarket steel, not to easy, no meat up there. They will get the stock TRW type pistons out of the hole though. $300 vs $800 set, could save some change.
[Re: camdog440]
#2054837
04/15/16 10:51 AM
04/15/16 10:51 AM
JohnRR
U.S.S.A.
Pin size is 1.094.
They are KB aluminum rods. Hello , is this thing on ??? Are they new or used ?
[Re: camdog440]
#2054842
04/15/16 10:55 AM
04/15/16 10:55 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
just make sure you check piston to head clearance. don't ask me how I know.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: JohnRR]
#2055128
04/15/16 07:58 PM
04/15/16 07:58 PM
camdog440
State of Corruption
Pin size is 1.094.
They are KB aluminum rods. Hello , is this thing on ??? Are they new or used ? They are new.
[Re: camdog440]
#2055277
04/15/16 11:58 PM
04/15/16 11:58 PM
Posts: 494 IL
EchoSixMike
IL
Has anybody used the hemi rod length in a wedge build?
I haven't found much on this other than a 4.15 stroke 494ci build in Hot Rod magazine in 1999.
Thanks! I'm using a 3.75 crank with a 6.965 rod and 1.12 CH pistons. Just because had parts laying around. S/F....Ken M
