Wiring harness ID. Late 70's, maybe 80's? #2053806
04/13/16 07:12 PM
04/13/16 07:12 PM
Missouri
68KillerBee Offline OP
Missouri
Any Google search I do comes up with nothing. I'm guessing it's from late 70's, maybe the 80's. Maybe someone finds it familiar looking. Part number 4055276. I received it with a bunch of NOS 1970's parts. Mostly car parts but there were some van/truck parts. Thanks!
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2053929
04/13/16 10:54 PM
04/13/16 10:54 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
If it's from the '70s, it would be late '70s. Looks like an '80s part to me but don't quote me.
I recently installed a '77 m.y. harness in my truck, has a black fuse box and the single strip connector for the turn signal similar to the cars.
'71 Duster
'17 Ram 1500
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2078549
05/23/16 12:06 AM
05/23/16 12:06 AM
Missouri
Missouri
Based on similar part numbers, I'm guessing this is roughly 1978-? trucks. But that's all I can come up with.
4055258 is stamped on the fuse block piece. Seems I'll need to find 1980s truck in a junkyard and see if they're similar to this. I appreciate the response, RMCHRGR
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2078570
05/23/16 12:35 AM
05/23/16 12:35 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Don't hold what I say as gospel as its been a number of years since I've messed with trucks, but, I think that is a fuse panel for an '81-'82?
'72 - '80 had the fuse panel mounted at the top of the dash next to the glovebox.
'81 was when the trucks got their face lift (and a new dash) which moved the fuse panel under the dash to a more conventional spot.
I'm thinking the first two years had the old style fuses then in '83 or '84 switched over to the blade type panel.
My twocents
John
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2078624
05/23/16 02:01 AM
05/23/16 02:01 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yeah, looks newer than 80.
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2105251
07/06/16 09:51 PM
07/06/16 09:51 PM
Missouri
Missouri
Thanks, I just remembered this post and checked back in. Trying to organize all these parts and will continue the search for one in a junkyard.
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2105474
07/07/16 09:01 AM
07/07/16 09:01 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Its definitely from an 81-82, possibly early 83
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2105782
07/07/16 05:43 PM
07/07/16 05:43 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
The fuse box isn't a 70s Dodge truck for sure. So I would go with an 80's model whatever.
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2106298
07/08/16 04:26 PM
07/08/16 04:26 PM
Missouri
Missouri
Thanks guys! Sounds like 77ProStreet is pretty sure with his answer, so that's what I'll go with.
Appreciate the replies.
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2109755
07/14/16 01:36 AM
07/14/16 01:36 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
That "tear tag" number should get a good parts man somewhere, I believe.
Re: Wiring harness ID. Late 70's, maybe 80's? [Re: 68KillerBee] #2110870
07/15/16 10:55 PM
07/15/16 10:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
77 diplomat or lebaron with air
