How strong is a sleeve in a stock block?
#2052360
04/11/16 11:58 PM
04/11/16 11:58 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
With the quality of the metals these days, is a sleeve as strong, not as strong, or the same strength as a stock big block? If it's stronger, can you get away with sleeving a 440 block for 400 bore safely. Just thinking out of the box.
[image][/image]
Re: How strong is a sleeve in a stock block?
[Re: sgcuda]
#2052526
04/12/16 02:18 AM
04/12/16 02:18 AM
Posts: 4,457 Washington
madscientist
Washington
Depends on the sleeve. You can sleeves that are far better than OE cast iron, or you can get them just like OE cast iron.
[Re: sgcuda]
#2052619
04/12/16 10:14 AM
04/12/16 10:14 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Kenny, when you figure the cost of sleeving all 8 cylinders w/ quality sleeves, plus all other associated machine work and parts...you're gonna wish you'd just started w/ an aftermarket block. I used to charge $125 labor per hole, plus decking, etc. Not to mention, sleeving one still does nothing to alleviate the problem w/ the BB mopar driving the mains out of stock blocks. Other than possibly saving a block w/ thin walls, you're not gaining anything.
[Re: sgcuda]
#2052705
04/12/16 12:41 PM
04/12/16 12:41 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
With the quality of the metals these days, is a sleeve as strong, not as strong, or the same strength as a stock big block? If it's stronger, can you get away with sleeving a 440 block for 400 bore safely. Just thinking out of the box. This is confusing , 440 bore is 4.320 , 400 is 4.342 ? 400 is .022 over a 440 ? Sleeves are usually stronger than the block they are being put it. I think to be safe with a 4.400 bore you'd need to sleeve it so the O.D. of the bores are touching? As stated it's going to cost you $$$$ to do that to an old 440 block, it would be more cost effective to buy a Megablock.
[Re: an8sec70cuda]
#2052791
04/12/16 02:46 PM
04/12/16 02:46 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Kenny, when you figure the cost of sleeving all 8 cylinders w/ quality sleeves, plus all other associated machine work and parts...you're gonna wish you'd just started w/ an aftermarket block. I used to charge $125 labor per hole, plus decking, etc. Not to mention, sleeving one still does nothing to alleviate the problem w/ the BB mopar driving the mains out of stock blocks. Other than possibly saving a block w/ thin walls, you're not gaining anything. I have a 1977 LA360 block that I was going to build for my truck, but it already is at .040 and #5 cylinder has two long grooves the length of the cylinder and probably will not clean up at .060 . I only paid $100.00 for the long block core with good big port iron heads and the truck oil pan, so I can afford to throw it out. Years ago I worked at a local Allis=Chalmers dealership as the parts manager and their engines all used sleeves and that is how you overhauled one of them when it was finally time for that.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: sgcuda]
#2052956
04/12/16 06:36 PM
04/12/16 06:36 PM
Posts: 4,209 New York
polyspheric
New York
There's a good chance that you're making your current block much more expensive before it begins to leak water, blow head gaskets, or explode.
BTW: you don't get anything like the same VE, torque or hp as: new size / old size = increase. E.g., 4.32" > 4.40" does not produce 3.7% more power.
Boffin Emeritus
[Re: sgcuda]
#2053159
04/12/16 11:03 PM
04/12/16 11:03 PM
sgcuda
Since my -1's have 2.25 intake valves, I was thinking that a 4.40 bore would be beneficial to help unshroud the airflow. I need to check out current prices at my local guy. I have a set of aluminum rods 6.7 long with SBC journals. Could offset grind almost any crank to give me decent stroke/displacement.
[image][/image]
[Re: sgcuda]
#2053517
04/13/16 10:51 AM
04/13/16 10:51 AM
an8sec70cuda
And you'll wind up w/ a ton of money in a stock block that will likely crack the main webs after a year or so. That's a lot of money for a minimal gain in power too...just unshrouding the valves a little. By the time you put aluminum caps on it and do all the other machining, you'll have as much in it as an aftermarket block but still be stuck w/ a grenade at your power level.
[Re: sgcuda]
#2053525
04/13/16 11:10 AM
04/13/16 11:10 AM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Additionally, I'd ONLY take it to someone who has successfully done this before. ..and I'd bet when you find that person they'll be OLD LOL. To those who say "no problem, other blocks are built with sleeves"...This doesn't translate because, those blocks are, BY DESIGN, engineered to utilize a sleeve. OR inherently may lend themselves BETTER to this process.
