Re: 69 Superbee quarter window assembly restore?
[Re: superbeedave]
#2052601
04/12/16 08:55 AM
04/12/16 08:55 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
Dave - They are a bit of a project and by the time you are done will be several hundred dollars in parts other than the glass.
The rear hasp is reproduced. The front weatherstrip on the vent window is available as well. The big trick is the hollow core rivets that hold it all together. This requires a special apparatus to replace them. A group of friends and I all pitched in to buy it, but I don't recall the exact name or price.
Not sure if this is of any help.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: superbeedave]
#2052613
04/12/16 09:49 AM
04/12/16 09:49 AM
Posts: 247 Wausau,Wisconsin
Kilrbee
Wausau,Wisconsin
Well Big D they are called semi-tubular rivets and we have about $400.00 invested in the press and dies for the different rivet sizes, and it was worth it because your quarter windows turned out very nice!! Dave I would be able to take your restored window components and do the assembly on them for a small fee, if you are interested PM me here and I will get back to you.
[Re: superbeedave]
#2052881
04/12/16 04:18 PM
04/12/16 04:18 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
In the book we wrote that is available on Amazon we step by step show you how to completely restore these. Including not having to use the hollow rivets. Car Tech - publisher SA327 Mopar B-body Restoration 1966-1970. Shaw/Wilkins
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#2054887
04/15/16 12:06 PM
04/15/16 12:06 PM
Posts: 34 SC
70B3VRR
SC
In the book we wrote that is available on Amazon we step by step show you how to completely restore these. Including not having to use the hollow rivets. Car Tech - publisher How to Restore 66-70 Plymouth and Dodge B-bodies. Shaw/Wilkins Where is this in your book? I can't find it.
[Re: 70B3VRR]
#2054931
04/15/16 01:51 PM
04/15/16 01:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
In the book we wrote that is available on Amazon we step by step show you how to completely restore these. Including not having to use the hollow rivets. Car Tech - publisher How to Restore 66-70 Plymouth and Dodge B-bodies. Shaw/Wilkins Where is this in your book? I can't find it. Go to page 114 here: http://www.flipdocs.com/showbook.aspx?ID=10011589_638690
[Re: DAYCLONA]
#2054962
04/15/16 02:43 PM
04/15/16 02:43 PM
MOPARMIKE69
Nashville, TN
Here is the link: Mopar B-body Restoration 1966-1970 http://www.amazon.com/s/ref=nb_sb_ss_i_1_8?url=search-alias%3Dstripbooks&field-keywords=mopar+b-body+restoration+1966-1970+book&sprefix=Mopar+B-%2Cundefined%2C195&rh=n%3A283155%2Ck%3Amopar+b-body+restoration+1966-1970+book
[Re: superbeedave]
#2055413
04/16/16 10:06 AM
04/16/16 10:06 AM
Big D A12
Wisconsin
Big D, I google that part number and it shows it for a hardtop and not a 2 door sedan with post and flip out windows. Thanks again, Dave This piece is the same for the front edge of hardtop and post front door windows. It is also correct for the front edge of the rear post vent windows. It is the weather strip the glass pivots in. D
[Re: Big D A12]
#2056270
04/17/16 05:58 PM
04/17/16 05:58 PM
Posts: 508 Cincinnati, Ohio
superbeedave
Cincinnati, Ohio
Big D, I google that part number and it shows it for a hardtop and not a 2 door sedan with post and flip out windows. Thanks again, Dave This piece is the same for the front edge of hardtop and post front door windows. It is also correct for the front edge of the rear post vent windows. It is the weather strip the glass pivots in. D I noticed that you were correct after I replied back to you. I have decided to reuse mine they are not cracked but some of the black felt has pulled off otherwise still good to save than to but a new strip. Thanks, Dave
[Re: superbeedave]
#2058387
04/20/16 02:26 PM
04/20/16 02:26 PM
superbeedave
Cincinnati, Ohio
Can someone tell me how thick and how wide the foam stripping that goes around the frame should be? Thanks, Dave
