Re: Hemi rotating assemblyl
[Re: cudaman1969]
#2053117
04/12/16 10:10 PM
04/12/16 10:10 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Use a shorter rod, then the pin won't be in oil ring. I'm almost sure the oil rings won't be in the wrist pin I would call the piston maker you want to buy from and ask them about the wrist pin location with your stroke and the 7.100 long rods The lomger the rods the lighter the pistons can be
[Re: Lost in life]
#2053339
04/13/16 01:39 AM
04/13/16 01:39 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have Eagle 4.5 crank with 2.2 rod journals , eagle 7.1 rods and Diamond 10.5 pistons in my 572 . Hemi's normally use a 8 bolt crank. Most distributors have all the items you need.
[Re: AndyF]
#2053347
04/13/16 01:57 AM
04/13/16 01:57 AM
Posts: 10,142 A Red State
SNK-EYZ
A Red State
Not sure if you'll be able to find a stroker kit or not but it isn't too hard to build your own. A 572 requires a 4.500 stroke crankshaft which you can get from SCAT, Callies, Molnar, etc. If it was me I'd use the Chevy 2.200 rod journals and then use a 7.100 long connecting rod. Then you just need pistons but those shouldn't be too hard to find. Diamond, JE, Ross, Wiseco, etc. can take care of you. If you want to use an internal oil pickup you will need to use the 2.200 size rod journals. As far as the Mopar Performance aluminum heads and valve gear, my M/Perf Edelbrock casting aluminum Hemi heads the springs went from 140 lbs of seat pressure down to 110 lbs of seat pressure in about 900 miles. Junk!
[Re: Lost in life]
#2053483
04/13/16 09:53 AM
04/13/16 09:53 AM
SNK-EYZ
A Red State
If you're starting from scratch on buying parts I'd say use the 2.200 size rod journals and eliminate the need for the external oil pick-up completely. If I would have known, I would have. It really depends on which block you start with on the external oiling system. If it's a Mopar Performance/World block that has the AN boss on the front of the number 1 cylinder it's not too bad. You basically need a pan mount swinging or fixed pick-up and a line to run it to the AN boss. You can use any normal style oil pump. Mine uses a regular Street Hemi oil pan with the swinging pick-up. How mine looked before paint. Without the AN boss you need a pump that uses an external oil feed line, which can run into engine mount clearance problems if you run factory style mounts. As far as the heads, if you replace the installed Mopar valve springs the Mopar Perf heads would probably be fine. Stage V heads might be a better option.
[Re: Lost in life]
#2053573
04/13/16 12:21 PM
04/13/16 12:21 PM
Posts: 2,653 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Thanks guys for the replies. I obviously need to learn more before bringing out the checkbook. Appreciate your knowledge. You don't need knowledge. That's what Ray Barton is for. All you need is a phone.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#2053664
04/13/16 02:39 PM
04/13/16 02:39 PM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
Use a shorter rod, then the pin won't be in oil ring. I'm almost sure the oil rings won't be in the wrist pin I would call the piston maker you want to buy from and ask them about the wrist pin location with your stroke and the 7.100 long rods The lomger the rods the lighter the pistons can be Mine are 3/16 into the oil ring, have to have a ring support. This is with a 7.045 rod.
[Re: Lost in life]
#2053749
04/13/16 04:52 PM
04/13/16 04:52 PM
rowin4
I did and would again call or e-mail Tim At FHO [for Hemi's only] for information about your build and what he can do for you.
[Re: cudaman1969]
#2053769
04/13/16 05:38 PM
04/13/16 05:38 PM
Cab_Burge
Use a shorter rod, then the pin won't be in oil ring. I'm almost sure the oil rings won't be in the wrist pin I would call the piston maker you want to buy from and ask them about the wrist pin location with your stroke and the 7.100 long rods The lomger the rods the lighter the pistons can be Mine are 3/16 into the oil ring, have to have a ring support. This is with a 7.045 rod. Which size wrist pin did you use, .990,1.040 or 1.07? Do you know how much your block deck has been cut? It has been a long while since I last assembled a 4.500 stroke 426 type Hemi motor so I may be not remebering correctly on the wrist pin location
[Re: Cab_Burge]
#2053784
04/13/16 06:26 PM
04/13/16 06:26 PM
cudaman1969
fredericksburg,va
Use a shorter rod, then the pin won't be in oil ring. I'm almost sure the oil rings won't be in the wrist pin I would call the piston maker you want to buy from and ask them about the wrist pin location with your stroke and the 7.100 long rods The lomger the rods the lighter the pistons can be Mine are 3/16 into the oil ring, have to have a ring support. This is with a 7.045 rod. Which size wrist pin did you use, .990,1.040 or 1.07? Do you know how much your block deck has been cut? It has been a long while since I last assembled a 4.500 stroke 426 type Hemi motor so I may be not remebering correctly on the wrist pin location Down .130 , 1.03 pin, 2.2 journal. A little wiggle room between crank and piston.
[Re: Lost in life]
#2054193
04/14/16 12:01 PM
04/14/16 12:01 PM
rickseeman
Stuttgart, Arkansas
I have had a few 572's (4.50" x 4.50"). All with Diamond pistons. Two with 7.1" rods and .990 pins (2.20" rods). Neither had the pin in the oil ring. I had one for heavy nitrous once that had thicker domes and the rings moved down. It had the pin in the oil ring.
[Re: rickseeman]
#2054258
04/14/16 01:53 PM
04/14/16 01:53 PM
cudaman1969
fredericksburg,va
I have had a few 572's (4.50" x 4.50"). All with Diamond pistons. Two with 7.1" rods and .990 pins (2.20" rods). Neither had the pin in the oil ring. I had one for heavy nitrous once that had thicker domes and the rings moved down. It had the pin in the oil ring. Hemi or RB? Hemi valve relief dictates lower ring pack.
[Re: Lost in life]
#2054498
04/14/16 08:07 PM
04/14/16 08:07 PM
cudaman1969
fredericksburg,va
Hmmmm.. Maybe I would just be better off going with a 4.25 stroke I think that would give me a 528 with the 4.5 bore correct? Might be a whole bunch simpler for this newbie. Thanks for the replies. Maybe 540 with 4.25 528 with 4.15
