Page 1 of 4 1 2 3 4
Car Wiring......... #2052642
04/12/16 11:20 AM
04/12/16 11:20 AM
North Alabama
Monte_Smith Offline OP
North Alabama
We have had many discussions about wiring cars, floating grounds, etc, so here are some pics of a recent job. First pic is "floating ground". All grounds in car come to this buss bar. Nothing grounded on chassis
Re: Car Wiring......... [Re: Monte_Smith] #2052649
04/12/16 11:30 AM
04/12/16 11:30 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Nice Monte thats how I did my grounds this time.
Ok
Re: Car Wiring......... [Re: Monte_Smith] #2052650
04/12/16 11:31 AM
04/12/16 11:31 AM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Monte I like that set up. Where can a guy pick up that buss bar?
Re: Car Wiring......... [Re: Monte_Smith] #2052653
04/12/16 11:33 AM
04/12/16 11:33 AM
North Alabama
North Alabama
More pics. Coil packs and outside grounds. There are multiple grounds out front for fuel pump, fans, water, lights. They all ground on this stud and then heavier wire runs from here to inside buss bar to cut down on wiring. Crank sensor wire is run inside main rail to isolate and eliminate RFI. Last pic is crank trigger dist modified to be a cam pickup
Re: Car Wiring......... [Re: BuckeyeBrawler] #2052662
04/12/16 11:43 AM
04/12/16 11:43 AM
North Alabama
North Alabama
It's for a boat, but I have made my own from copper strap. Simply make a strap, drill some holes in it with several bolts for ground studs and mount it to the chassis on rubber isolators. I was out of copper and found this piece........but it worked nice
Re: Car Wiring......... [Re: Monte_Smith] #2052665
04/12/16 11:47 AM
04/12/16 11:47 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
The Reaper?
Re: Car Wiring......... [Re: GY3] #2052682
04/12/16 12:13 PM
04/12/16 12:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
This forum is very aggravating to me anymore. None of the pictures are loading on this thread at work. They load on some other threads. I don't get it. Most of the time the parts for sale pictures don't load.
I checked my phone so I got to see the beautiful work, just a smaller version of what I should be looking at.
Monte, you do nice work. You should get paid for it
Re: Car Wiring......... [Re: Monte_Smith] #2052686
04/12/16 12:20 PM
04/12/16 12:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Monte.. I see you drilled a hole in the chassis
tube.. I didnt think that was allowed... plus you
forgot the grommet.. the whole job looks good
wave
Re: Car Wiring......... [Re: Monte_Smith] #2052703
04/12/16 12:38 PM
04/12/16 12:38 PM
North Alabama
North Alabama
Nearly all pro built cars have wiring, fuel, brake lines, whatever run inside the frame rails. The grommet is in it now.
Don't worry Ray........I DO.........LOL!!!
Re: Car Wiring......... [Re: Monte_Smith] #2052707
04/12/16 12:42 PM
04/12/16 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt know that holes were allowed... wish I would
have known that long ago
wave
Re: Car Wiring......... [Re: Monte_Smith] #2052733
04/12/16 01:27 PM
04/12/16 01:27 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Very nice Monte
72 Plymouth Roadrunner 11.08@123.25
Re: Car Wiring......... [Re: Monte_Smith] #2052738
04/12/16 01:38 PM
04/12/16 01:38 PM
Oklahoma
66 Belvedere Offline
Oklahoma
Very nice Monte
Ray
Re: Car Wiring......... [Re: Monte_Smith] #2052769
04/12/16 02:28 PM
04/12/16 02:28 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Nice job, Yes the buss bars can be picked up at most marine supply stores. They have many sizes, at least the place I got mine at did. Boats have so neat switch panels also . I used them as shown for the grounds and for misc. hot wire interior gauge lights.
Re: Car Wiring......... [Re: 66 Belvedere] #2052774
04/12/16 02:32 PM
04/12/16 02:32 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I love to see how others (Professionals) do this kind of work. I had issues in the past with the electrics on my old racer. I am trying to absorb as much as I can and apply it to the new ride (My Junk), but it won't be as nice as this.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Car Wiring......... [Re: Monte_Smith] #2052781
04/12/16 02:39 PM
04/12/16 02:39 PM
North Alabama
North Alabama
Wiring is NOT hard, if you understand how things work. Just time consuming and hard to make look nice. Mine never looks as nice as I WANT it to.
On EFI cars I always use the unterminated universal harness and build my own, because to me, the plug and play harness looks like an octopus and I don't use near whats in a stock harness anyway. You can look at my ECU plugs and see I use the bare minimum and pull out anything unused
Re: Car Wiring......... [Re: Monte_Smith] #2052826
04/12/16 03:15 PM
04/12/16 03:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Car Wiring......... [Re: Monte_Smith] #2052832
04/12/16 03:23 PM
04/12/16 03:23 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The biggest problem with most people wiring a car themselves is, they think zip ties are expensive...
Nice work Monte.
Jeff
69 GTX 68 Road Runner
Re: Car Wiring......... [Re: Monte_Smith] #2052846
04/12/16 03:33 PM
04/12/16 03:33 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
The good ones aren't exactly cheap! haha
I am finishing up a small wiring project, and the wiring doesn't look horrible, but definitely doesn't look as good as I would have liked.
Nice work Monte!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Car Wiring......... [Re: Monte_Smith] #2052862
04/12/16 03:55 PM
04/12/16 03:55 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Outstanding work Monte!
Brett Miller 447 W9
Re: Car Wiring......... [Re: Monte_Smith] #2052894
04/12/16 04:32 PM
04/12/16 04:32 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
not trying to hi-jack, but is there a proper orientation to a relay? As in right side up? I thought I read somewhere that the g forces of a drag car could cause the contacts to open under acceleration.
Page 1 of 4 1 2 3 4
