annular boosters, holley hp vs quick fuel
#2052279
04/11/16 10:52 PM
04/11/16 10:52 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
so i've decided on a annular booster carb. I understand that with these boosters, you lose CFM, so the advertised number, is higher than it actually flows. I think i've read that the quick fuel carbs have booster inserts, that help keep the CFM loss to a minimum. i was thinking of the 1,000 cfm hp or the 1050 quick fuel, 4150 based. what i'm wondering is, what would be better for my car? mild 526 stroker, nothing crazy, ( i'm still waiting for all the specs on it) it made 550is hp and about 630lbft. it's in a 4400lb wagon, 2600 stall and 3.73's. it'a a street car, thats gets driven, to work, the store, the 3 hour ride to Carlisle, etc. i just don't want to under carb it. it has a performer rpm, not the best, but i have no hood clearance. would the hp be alright, or should i step up the the quick fuel?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: annular boosters, holley hp vs quick fuel
[Re: Spaceman Spiff]
#2052299
04/11/16 11:07 PM
04/11/16 11:07 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
My QF SS-750-AN is called a 750 but QF told me it's actual flow is 735cfm with the annular boosters. You may not be loosing much more if any with the larger QF 1050.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#2052647
04/12/16 11:30 AM
04/12/16 11:30 AM
Posts: 304 Florida
Mark Whitener
I wouldn't worry at all about losing flow with a carb that size. With dyno time I've done an annular makes up for most if not all of the power lost from less air due to better atomization and vaporization, that leads to better distribution. The 4150 style annular carbs use a booster that is .600 thru the center versus a .500 center a Dominator uses, which loses less flow. Have you considered something custom? When building I prefer the BLP baseplates, the t-slots are smaller which make the idle and part throttle smoother. Quick fuel bodies have a better entrance shape, they flow better on the flow bench than the Holley. BLP billet bodies are another good choice. And there is custom work that can be done with boosters to help flow and signal a little more, and improve atomization.
Mark Whitener [url=www.racingfuelsystems.com[/url]
