motor plate water pump gasket problems #2052306
04/11/16 11:15 PM
04/11/16 11:15 PM
Amherst,NY
challengermike Offline OP
Amherst,NY
Anyone else have problems using a motor plate and having the water pump gaskets leaking. It's a A body with a 440. I have to replace the gaskets at least once a year due to them leaking. I have flat sanded the plate, tried lock tight and lock washers on the bolts and ultra grey rtv on the gaskets. Any idea's would be great.
Re: motor plate water pump gasket problems [Re: challengermike] #2052313
04/11/16 11:22 PM
04/11/16 11:22 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Use Superformance gaskets and you'll have no leaks.
Member Roadhazard is the owner of the company.
Nautilus Racing-
Re: motor plate water pump gasket problems [Re: challengermike] #2052314
04/11/16 11:22 PM
04/11/16 11:22 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Is it a plate or two piece ears? I've had the ears leak due to flex. Made tabs at the bottom of the plate to tie it into the timing cover to reduce flex. The empty hole in the 1st pic next to the crank trigger bracket is where the tab bolts. Decided to bolt a tab rather than weld it in case the timing cover needed to come off in the car. In the 2nd pic you can see the tabs at the bottom. 3 years no leaks.
Doug
Re: motor plate water pump gasket problems [Re: challengermike] #2052316
04/11/16 11:24 PM
04/11/16 11:24 PM
Amherst,NY
Amherst,NY
Yes it is the 2 piece ears. I never thought about it flexing.
Re: motor plate water pump gasket problems [Re: Chris2581] #2052320
04/11/16 11:26 PM
04/11/16 11:26 PM
Amherst,NY
Amherst,NY
I will check those gaskets out.
Re: motor plate water pump gasket problems [Re: challengermike] #2052331
04/11/16 11:34 PM
04/11/16 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ears will let the engine pivot on the mount
bolts.. you have to lock it solid to the engine
(and the bolts wont do it.. a solid plate is
the best bet)
wave
Re: motor plate water pump gasket problems [Re: challengermike] #2052333
04/11/16 11:36 PM
04/11/16 11:36 PM
NC
440Jim Offline
440Jim  Offline
NC
Although I had a one piece front plate, I found that after awhile (months) gaskets could leak. Then I just used only RTV (no gaskets) and it never leaked again.
Re: motor plate water pump gasket problems [Re: 440Jim] #2052371
04/12/16 12:04 AM
04/12/16 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I only use RTV on my SB junk.. it has never leaked
wave
Re: motor plate water pump gasket problems [Re: 440Jim] #2052397
04/12/16 12:18 AM
04/12/16 12:18 AM
Amherst,NY
Amherst,NY
That's 1 thing I never tried, I think I might try it this time. If it leaks again I think I might find a different k frame and use solid mounts or make my own mounts on the k frame that in it now.
Re: motor plate water pump gasket problems [Re: challengermike] #2052398
04/12/16 12:19 AM
04/12/16 12:19 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I found that the bolts would loosen during the season due to flexing. I check them regularly. Also, be sure to have an engine limiter to prevent fore/aft movement.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: motor plate water pump gasket problems [Re: challengermike] #2052402
04/12/16 12:21 AM
04/12/16 12:21 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Never had a leak (1 piece plate) when sealed with Hylomar. And there is no cure time.
Re: motor plate water pump gasket problems [Re: Dads426] #2052404
04/12/16 12:22 AM
04/12/16 12:22 AM
Amherst,NY
Amherst,NY
My bolts were still tight this time but I don't have anything on it for the fore and aft movement, I thought the trans mount would be enough but maybe not.
Re: motor plate water pump gasket problems [Re: jughed] #2052411
04/12/16 12:26 AM
04/12/16 12:26 AM
Amherst,NY
Amherst,NY
Is that like the stuff gm use's on the front diff case half and t case half ? There's is red though.
Re: motor plate water pump gasket problems [Re: challengermike] #2052422
04/12/16 12:33 AM
04/12/16 12:33 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
[/quote]My bolts were still tight this time but I don't have anything on it for the fore and aft movement, I thought the trans mount would be enough but maybe not. [/quote]
When we got the car it didn't have a limiter and the trans mount was toast. After a new quality rubber mount and a S&W limiter the mount looks like new after 5 years.
Re: motor plate water pump gasket problems [Re: challengermike] #2052428
04/12/16 12:36 AM
04/12/16 12:36 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i don't know about the GM stuff, but what i use is a light blue. Also use it around the water holes with SCE copper head gaskets (o-ringed block). So far, there have been no leaks there either.
Re: motor plate water pump gasket problems [Re: Dads426] #2052430
04/12/16 12:37 AM
04/12/16 12:37 AM
Amherst,NY
Amherst,NY
When we got the car it didn't have a limiter and the trans mount was toast. After a new quality rubber mount and a S&W limiter the mount looks like new after 5 years. [/quote]
I will check the mount and look into a limiter.
Re: motor plate water pump gasket problems [Re: challengermike] #2052460
04/12/16 01:00 AM
04/12/16 01:00 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
2 piece ears are difficult because of the flexing as said.
With that being said I would never, never, never use a silicone sealant on any joint that was flexible and difficult to seal with a gasket. What happens when you flex the joint and break the elastic bond/adhesion between components, under pressure?
My advise to the OP is modify the ears to be one or buy a one piece plate coupled with some quality gaskets. Make life easy.
Re: motor plate water pump gasket problems [Re: challengermike] #2052502
04/12/16 01:49 AM
04/12/16 01:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Ditch the gaskets. Use rvt, then you can really tighten the bolts (no crushed gaskets), and it won't leak again.
Re: motor plate water pump gasket problems [Re: challengermike] #2052585
04/12/16 06:46 AM
04/12/16 06:46 AM
Wild West
M_D Offline
M_D  Offline
Wild West
RTV works for me. If you have a 2 piece mount and you install them with the outside ends hanging down then when the engine is installed in the chassis it will tend to rotate the outside ends up. Depending on the clearance between the bolts and the holes it could be quite a bit. Preloading the ears in the direction the engine weight will force them later will reduce the movement.
I prefer to use studs that are threaded on both ends with a smooth shank section in the area that the engine bears on. It makes installation and alignment easier plus the smooth shank has more bearing area.
Re: motor plate water pump gasket problems [Re: challengermike] #2052597
04/12/16 08:36 AM
04/12/16 08:36 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
1 piece plate, used gaskets for years ,always problems with leaks and bolts loosing up,use rtv, have not had an issue in 5 years.took the advice from a moparts poster,pat
