What would cause the PCV valve to 'buzz'? #2052426
04/12/16 12:35 AM
04/12/16 12:35 AM
Between Houston & Galveston TX
SattyNoCar Offline OP
Subject: '93 Dakota with the 3.9 V6 w/165K miles
For about a week I've been getting a very random, single dead miss, usually when sitting at a light, or just as I take my foot off the brake to pull away from the light. After that, accelerating or at steady cruise, I haven't felt a miss.
Tonight, it misfired a bunch of times in a row then went back to usual, except I was hearing a new noise. Investigating while the truck was idling, I found the PCV valve just buzzing away.
Truck feels no different. No loss of power, idles as smooth as before (well, between the random dead miss).
I replaced the plenum a year ago (used the Hughes kit) just after I bought the truck. I also replaced plugs, wires, cap, filters at that time too (about 8K miles).
And its supposed to rain the next two days.
Suggestions? Ideas?
Thanks.
John
Re: What would cause the PCV valve to 'buzz'? [Re: SattyNoCar] #2052560
04/12/16 03:14 AM
04/12/16 03:14 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I've had them do that back in the old days. I would usually clean them first off only to replace them. The check valve spring gets weak over time is my guess.
Re: What would cause the PCV valve to 'buzz'? [Re: SattyNoCar] #2052651
04/12/16 11:31 AM
04/12/16 11:31 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
My '96 3.9 Dak with 195k on the clock runs perfect but the PCV has been doing the same thing for about the last 5 years. Replaced the PCV, no help. Now I just ignore it.
Re: What would cause the PCV valve to 'buzz'? [Re: SattyNoCar] #2052771
04/12/16 02:30 PM
04/12/16 02:30 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
My truck has about 80K on it. Never did this until I replaced my PCV as part of routine maintenance. Tried 2 other brand PCVs, same issue. I threw out the old one before I noticed this. Wish I didnt.
Mine seems to do it for a few minutes after start. After it is fully warmed up or hot, not so much.
Re: What would cause the PCV valve to 'buzz'? [Re: SattyNoCar] #2066228
05/02/16 11:34 PM
05/02/16 11:34 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Get a mopar one. It solved my problem.
