Max Wede Ports #2050136
04/09/16 01:28 AM
04/09/16 01:28 AM
In a house near you
Street Monkies Offline OP
In a house near you
Anyone successfully take 440 source heads out to max wedge size ports? Is it worth the effort, and if not the max wedge size what is the next largest size? Thanks
Re: Max Wede Ports [Re: Street Monkies] #2050332
04/09/16 11:59 AM
04/09/16 11:59 AM
Idaho
LaRoy Engines Offline
Idaho
Why do you ask?
Re: Max Wede Ports [Re: Street Monkies] #2050446
04/09/16 03:45 PM
04/09/16 03:45 PM
In a house near you
In a house near you
Because I would like to know. Thanks
Re: Max Wede Ports [Re: Street Monkies] #2050481
04/09/16 04:46 PM
04/09/16 04:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As with just about all aspects of engine building, the answer is, "it depends".
The more ported the heads are, the bigger the engine displacement, cam, compression, etc, the more difference it will make.
On an ootb rpm head I don't think making the port opening mw size would do much of anything for flow.
Re: Max Wede Ports [Re: Street Monkies] #2050488
04/09/16 04:58 PM
04/09/16 04:58 PM
In a house near you
In a house near you
I got 499" so it's not that the engine isn't big enough it's the heads. I haven't gotten a cam yet so I can't say on that yet. I'm sure it will be around 12:1.
Re: Max Wede Ports [Re: Street Monkies] #2050495
04/09/16 05:14 PM
04/09/16 05:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
on the SUPER stealth heads it helps flow.
Re: Max Wede Ports [Re: Street Monkies] #2050519
04/09/16 06:03 PM
04/09/16 06:03 PM
AndyF Offline
AndyF  Offline
The problem with putting a MW port on a standard head (besides the questionable increase in flow) is that it creates a problem for sealing the valley.
Indy heads are designed to seal the valley but standard heads are not. On an RB block you can use the 337 intake (if you can find one) but there isn't a good solution for a low deck.
Re: Max Wede Ports [Re: Street Monkies] #2050661
04/09/16 10:39 PM
04/09/16 10:39 PM
In a house near you
In a house near you
I thought you could seal the valley with 440 source heads?
Re: Max Wede Ports [Re: Street Monkies] #2052175
04/11/16 09:32 PM
04/11/16 09:32 PM
In a house near you
In a house near you
If max wedge can't be done safely, what is the next size down?
Re: Max Wede Ports [Re: Street Monkies] #2052190
04/11/16 09:50 PM
04/11/16 09:50 PM
Wild West
M_D Offline
M_D  Offline
Wild West
If you want to use readily available intake gaskets, as far as I know there are just the standard size and max-wedge sizes. If you want to make your own gaskets you can make it any size you like.
The problem with low port heads is it's harder or clumsier to make a separate solution to seal the valley. Custom manifold gaskets to seal just the ports are not that big of a deal to make or have made.
If choices in heads were slim, it might be worth it. If it was a straight forward thing to change to custom port size it might be worth it. But since there are so many head choices it might be more effective to buy another set of heads that don't need to customized and sell what you have.
If for some reason I was going to modify a head to a custom port size and location and there wasn't a solid solution to seal it all up available then I would fabricate the parts and weld it all up to seal like most other V-8 engines.
Re: Max Wede Ports [Re: Street Monkies] #2052201
04/11/16 10:01 PM
04/11/16 10:01 PM
If you want M.W. intake ports buy a set of heads made with them to start with up I swapped heads on my old pump gas low deck stroker motor five times, from ported big valve iron 906 heads to a set of CNC ported Eddy RPM, then to a set of Indy M.W. SR and finally a set of 440-1 heads that flowed 370 CFM at .700 lift shruggy The bigger the head flow the more power the motor made on the engine dyno test at it ran faster at the track also boogie
If I was you I would put a goal down for HP, torque and RPM and then buy the parts to acheive that goal thumbs twocents work
Re: Max Wede Ports [Re: Street Monkies] #2052249
04/11/16 10:32 PM
04/11/16 10:32 PM
In a house near you
In a house near you
Thanks for the input guys.
