Re: Gunk Lead Substitute
[Re: Merlin45]
#2051128
04/10/16 04:30 PM
04/10/16 04:30 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Those Eddy heads come with hardened exhaust seats. I wouldn't bother with additives. Frankly I don't see where all this anti-wear stuff comes from. Had a set of 915's that were ran with unleaded gas for 20+ years on its soft iron seats, and wear was what one would expect to find with today's standards. Lead is used in racing fuels because it is a very effective octane booster.
However I, like you, am no expert. More knowledge will chime in I'm sure.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DZJim]
#2051962
04/11/16 04:54 PM
04/11/16 04:54 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
i always thought lead was primarily used as an exhaust valve lubricator and seat protector rather than an octane booster. it may offer some boost, but ?? clarify please, any chemists out there ? Where'd you get that idea? Apparently you always thought wrongly... https://en.wikipedia.org/wiki/Tetraethyllead Evidently you need to do some more research, the chemical, Tetraethyl(SP?P) was added to lubrictate the valves and valve seats to prevent burning the valves and pounding valve seats out, it is not a octane booster The higher you refine gasoline the more octane you will get, but less volume per gallon of crude for the higher octane products
[Re: Merlin45]
#2051984
04/11/16 05:37 PM
04/11/16 05:37 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Why is does race gas contain lead? Surely engines built today would have hardened seats. And not require lead.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Merlin45]
#2052020
04/11/16 06:35 PM
04/11/16 06:35 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Lead is added for octane and also protects the seats by padding them with deposits. Lead was removed and octane went in the crapper. It is very complicated and expensive to get much more than 100 octane gasoline without lead, that is why ethanol is so great.
[Re: Cab_Burge]
#2052077
04/11/16 07:44 PM
04/11/16 07:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Evidently you need to do some more research, the chemical, Tetraethyl(SP?P) was added to lubrictate the valves and valve seats to prevent burning the valves and pounding valve seats out, it is not a octane booster The higher you refine gasoline the more octane you will get, but less volume per gallon of crude for the higher octane products No, you are wrong http://www.environmentalhistory.org/billkovarik/about-bk/research/cabi/ket-tel/It's other benefits were secondary at the time.
[Re: Supercuda]
#2052187
04/11/16 09:49 PM
04/11/16 09:49 PM
Cab_Burge
Did any of you guys read this entire paper and links? I didn't read all the links but I did read most of the paper You guys need to remember or become aware that all early gasoline(pre 1950s) was white gas(Coleman lantern fuel), not the gasoline we know today I started pumping gasoline in a service station in the mid 1950, most American produced gasoilne burning automotive 4 cylinders, 6 cylinders and V8 engines at that time had less than 8.0 to 1 compression ratios The higher octane gasoline fuels(130/145 octane) used and developed in the WW2 era where for low RPM aircarft engines used in combat, most of them where supercharged, turbocharged or both The paper linked above is written either by a engineer or Professor or a perhaps PHD canidate Doctortate thesis as a research paper so it is filled with his opinions and the links to his sources justify his opinions Is his work, his or her opinion, the absolute truth? Maybe, maybe not My degree is not in chemistry Todays engines that run on todays gasoline are designed for today gasoline with no lead additives, do they have Iodine additives in todays fuels as a octane booster? Have any of you used or tried to use Toulene or Toulol or Benzine or MEK or Acetone with Methanol alchlol in race gasoline to go faster? I have Lots of ways to skin the kitty to get results, not all of them are the only way or the best way Please do not confuse antiknock chemical results with increased octane ratings
[Re: Merlin45]
#2052384
04/12/16 12:11 AM
04/12/16 12:11 AM
Posts: 5,162 CT
GTX MATT
CT
Sorry guys I have to disagree. Lead was discovered as an octane booster in the early 1920s by Charles Kettering under the direction of GM as an employee of Delco (which he owned and sold to GM). The sole purpose of his work was to find a cheap and effective octane booster, because those 20 hp engines in the 1910s had 6ish:1 compression. Oil comes out of the ground with an octane of about 60. The lubrication benefits are secondary (they actually had to add another additive to keep the lead from building up/sticking to everything), lead is an incredibly effective octane booster, and also helps keep engines cool as well as lubricate the valve seats.
I did quite a bit of research on the history of this a few years back, it was absolutely put into use as an octane booster. Excerpt below from his Charles Kettering's Wikipedia page and sums it up well.
"Kettering's research in fuel was based on his belief that oil would be in short supply and additives would allow more efficient engines with higher compression. His "high percentage" solution was to mix ethanol with gasoline, while his "low percentage solution" looked for additives that would be added in small quantities to increase what later would be called the octane rating of gasoline.[18] Thomas Midgley, Jr. and Kettering identified tetraethyllead (TEL) in December 1921 as an additive that would eliminate engine knocking at a dilution of one thousand to one.[18] While use of ethanol could not be patented, TEL's use as an additive could. Kettering and Midgley secured its patent and proceeded to promote the use of TEL as an additive instead of other options.[19] Kettering became the first president of the newly founded Ethyl Corporation that started to produce TEL in 1923.[20]"
[Re: GTX MATT]
#2052636
04/12/16 10:45 AM
04/12/16 10:45 AM
Posts: 19,406 north of coder
moparx
so, is tetraetheyl a different compound[additive] than tetraethyllead ? or are they one and the same ? was the "original" intent to find an exhaust valve lubricator/seat protector and a "side" benefit turned out to be an octane booster ? was "lead" added to tetraethyl after in search of the original intent ? if one reads everything published on the subject that dates ONLY from the late teens to the late 20's, the matter can be interpreted both ways. wiki is a valuable resource, but sometimes can be edited by someone that may have some facts slightly skewed, not necessarily caught by experts in the topic. just wanting to learn. i was also under the impression GULF "NO-NOX" [i think that was the brand] in the 60's was "clear gas", which was in reality, unleaded. who can clarify this ? if not true, which brand was it ? and where did that info come from ? we are no all "rocket scientists" here, but have a quest for knowledge that puts the "myth busters" to test.
[Re: moparx]
#2052640
04/12/16 11:15 AM
04/12/16 11:15 AM
Posts: 5,162 CT
GTX MATT
CT
so, is tetraetheyl a different compound[additive] than tetraethyllead ? or are they one and the same ? was the "original" intent to find an exhaust valve lubricator/seat protector and a "side" benefit turned out to be an octane booster ? NO! Thats bass ackwards. It was an octane booster that turned out to be a valve seat lubricator/seat protector. Tetraethyl can not exist on its own, it exists in compounds with other elements, lead being one of them. When someone talks about lead in gas, they mean tetraethyl lead. And yes, its just Wikipedia, I did my research elsewhere. Still not convinced? Try the wiki for TEL... https://en.wikipedia.org/wiki/Tetraethyllead
[Re: GTX MATT]
#2052850
04/12/16 03:39 PM
04/12/16 03:39 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: stumpy]
#2052930
04/12/16 05:47 PM
04/12/16 05:47 PM
Posts: 5,162 CT
GTX MATT
CT
Right, I believe everything the nation says. You betcha. Even that article states it was an octane booster though, I didn't read the entire thing but the history/background is accurate.
[Re: Merlin45]
#2052985
04/12/16 07:17 PM
04/12/16 07:17 PM
DARTH V8Я
Its a TRAP!
Toluene. Can't beat it for 3 bucks/gal.
