Re: Thermostat, restrictor revisited
[Re: justinp61]
#2050616
04/09/16 08:59 PM
04/09/16 08:59 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That's good info.
Apparently those 6 x 1/8" holes werent big enough to have enough coolant circulating by the t-stat to have a smooth operation.
[Re: fast68plymouth]
#2050756
04/10/16 01:36 AM
04/10/16 01:36 AM
RapidRobert
that confirms why Ma had such a large bypass on SB's. I've always wondered about that. On a side note unless it is a drag only I would think 160 is TOO cool. I would want 180 at a minimum
