stock 440 damper length or depth #2050073
04/08/16 11:29 PM
04/08/16 11:29 PM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
Hello
I'm looking for the length from the damper hub "part that touches crankshaft timing sprocket and the face where the pulley mounts. I want this for a stock 69 440, I looked online and could not find it.
If someone had one laying around and could measure it I would appreciate it.
Kevin
Re: stock 440 damper length or depth [Re: beecrazy] #2050096
04/09/16 12:25 AM
04/09/16 12:25 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
use a depth mic. and have it machined to the depth you want
Re: stock 440 damper length or depth [Re: beecrazy] #2050558
04/09/16 06:50 PM
04/09/16 06:50 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Not accurate to a couple of thou, but just about 1 3/4". Other end of the tape is flat against the table. Balancer is from a '72 steel crank 440.
