feul lines for e body? #204917
01/26/09 03:11 PM
01/26/09 03:11 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi all my feul lines were all rusted when I took the 73 barracuda apart. Iam planning on running new braided lines from tank to mechanical pump on the 340 and from tank to the spot where charcoal cannister used to be. Does anyone have the size and length that I would need? Thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: feul lines for e body? [Re: Islandcuda] #204918
01/26/09 04:18 PM
01/26/09 04:18 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
thats going to be a LOT of money. you need either 5/16 or 3/8" line depending on what you have now. you probably have 5/16" (i dont think they had the 3/8" in 73 but i dont know for sure)
Check out inlinetube for brand new fuel lines pretty cheap
Re: feul lines for e body? [Re: aarcuda] #204919
01/28/09 01:53 AM
01/28/09 01:53 AM
I
I
Thanks aarcuda you are right, i see even at the paddock they are cheap. I,m wandering what size I should order, would ordering the 3/8 cause me problems?
Re: feul lines for e body? [Re: Islandcuda] #204920
01/28/09 10:49 AM
01/28/09 10:49 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i upgraded my 5/16 to 3/8.
just need to get the 3/8 sending unit and block off the return port on it with a piece of fuel line hose a bolt and some hose clamps. Then you will need to change the inlet fitting on the fuel pump to 3/8". if you want, you can go further (like I did( and change the outlet fitting and line to the carbs to 3/8.
the new line goes in pretty darn easy. i was amazed because i thought it would be a pita. just remove the rear tires and jack it up and thread it through
Re: feul lines for e body? [Re: Islandcuda] #204921
01/28/09 12:19 PM
01/28/09 12:19 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Tim......you can get the lines right here on the Island. CLT in Victoria stocks the lines. I had ours in a day!!
1-888-474-5343. Can't remember the guys name but give them a call.
Richard.
