Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 #2048971
04/07/16 04:48 PM
04/07/16 04:48 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Would this Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 fit on a 344 with ported J heads 2,02-1,60 M-1 intake Holley 650Hp Headers in a -65 Valiant. 727, shiftkit and 8 3/4 with 5,38 29X10,5 Bracket/stripcar.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2048973
04/07/16 04:51 PM
04/07/16 04:51 PM
Washington
madscientist Offline
Washington
With that gear you could do it. Just make sure you have piston to valve clearance. And retainer to guide clearance. You would be running 10*'s more at .050 than I am, and about .030 less lift.
I almost bought that cam but they were on back order so I ordered a custom cam.
Edit: FWIW I think your carb is too small. You could use an 850 pretty easily. Hope you have at least 1.75 headers, if not bigger.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: madscientist] #2048989
04/07/16 05:17 PM
04/07/16 05:17 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Last cam went flat. I do have race fenderwell headers. I have the cam, came with the car.
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2048997
04/07/16 05:33 PM
04/07/16 05:33 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
I have a Comp Cams hydraulic cam as well! Xtreme Hi-Lift, XE285HL
Serious Street/Strip
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049003
04/07/16 05:39 PM
04/07/16 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never used that cam.. do you know the duration
at .050... is this a 1/4 mile or 1/8 mile car..
if its a 1/4 I dont think it will rev high enough
with that gear... but with that steep of gear I'm
thinking 1/8 car
EDIT
By the way... love the chopped roof line
wave
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049019
04/07/16 05:56 PM
04/07/16 05:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It's 270 @ .050, 106lsa
I would want pretty good compression and plenty of stall if I were hoping to be satisfied with the results.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049020
04/07/16 05:56 PM
04/07/16 05:56 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Duration at .050'': 265°/265°
Im just trying to get something together to go racing while I build my fuelaltered! Mostly 1/4 mile!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049024
04/07/16 06:01 PM
04/07/16 06:01 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Maybe I use the Comp Cams hydraulic cam insteed! Xtreme Hi-Lift, XE285HL
duration at 050 241/247, lift 0,545/0,545
This is a flattop piston engine.
Runs high in the front sometimes too!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049034
04/07/16 06:08 PM
04/07/16 06:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think you'll be disappointed trying to use that hyd cam with 5.38 gears.
Those xe/hl cams usually struggle to get past 6000rpm.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049041
04/07/16 06:15 PM
04/07/16 06:15 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
I will save the hydraulic for a street stroker then!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049046
04/07/16 06:20 PM
04/07/16 06:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
It's like many things that involve racing.......... The worst part to use in any situation is...... The one you already own.
Provided you have enough spring, and retainer to seal clearance, and v/p clearance, a couple of decent cams for a flat top 340 would be a Comp 20-635-5, or a 20-618-5.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049054
04/07/16 06:26 PM
04/07/16 06:26 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Yes I know! To many leftovers from different builds! Have a pair of W-2 also if they fit the cam better! But then the headers dot fit well on the exhaustport!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049111
04/07/16 07:13 PM
04/07/16 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself... I would run the W-2s.. cut the flanges
off the headers and weld on new ones for the W-2s..
its a pretty simple job IF the tubes are big enough
for the rpm you will run.. as Fast said.. forget the
hyd cam.. it'll never make the rpms you need
EDIT
For the headers.. I normally make a mandrel that
I would drive into the tubes at the flange for the
shape of the port.. pretty simple.. heat some times
was needed.. most of the time it wasnt
wave
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049160
04/07/16 08:06 PM
04/07/16 08:06 PM
Colorado Springs, Colorado
Dartthunder340 Offline
Fed,your combination is very similar to what I'm running in a Dart. I would use the W2 heads also, have them on mine and very happy with them. I haven't put in the 5.38's yet, still with 5.13's. Should also add that I'm pretty happy with the .590 Purple Shaft. Pretty old school build but it's proven and I am enjoying it...when I can get away to race!
Better get inside Ma. Looks like a storm's comin'.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049257
04/07/16 10:07 PM
04/07/16 10:07 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I used the 590 purple shaft on my big block tunnel ram. Shifted at 6,800 rpm, through the lights at 6,500 rpm. 3150 pounds 4.88 gears 10.80's. Very dependable, consistant times, easy maintenance.
[image][/image]
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: sgcuda] #2049647
04/08/16 01:05 PM
04/08/16 01:05 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
I ran a similar combination. Stock stroke 360, ported j heads, 590 cam, victor manifold. 904, 4.88 gear, 65 valiant. Ran 10.20's @ 130... i think you have too much gear like others have said.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2049715
04/08/16 02:42 PM
04/08/16 02:42 PM
Guitar Jones Offline
It's very difficult to get enough valve spring and installed height on those iron heads to really use that cam.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: Guitar Jones] #2050080
04/08/16 11:45 PM
04/08/16 11:45 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
I never had a problem. Put 2 motors together that were pretty much identical bolth with that cam. Springs were never a problem....
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: fed] #2051273
04/10/16 08:10 PM
04/10/16 08:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
People always crack jokes about purple shaft cams but I loved my 590 in my old 451" low deck with Eddy heads, it went 9.80's in my old DartSport and was very streetable. That's as fast as I wanted to go on a tight budget.
Re: Mopar Perf. ''Purple Shaft'' Mechanical Camshaft 312/590 [Re: BIG DRAG] #2054647
04/14/16 11:18 PM
04/14/16 11:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's a good running combo. When I ran the 557 purpleshaft in my 340 years ago I was running 11.70's and there was a guy with a 340 Dart there that was running a very similar combo but he was running the 590 cam and was going 11.20's. That's kinda what made me want to try the 590 in my big block car and it ran extremely well.
It's hard to go wrong with a cam and lifter kit for around $170!
Fast68Plymouth recommended a couple Comp cams so I would definitely look into those.
