oil pump drives #2048820
04/07/16 01:46 PM
04/07/16 01:46 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Will i be able to use my old 440 oil pump drive with the 400 based motor ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: oil pump drives [Re: deaks] #2048833
04/07/16 02:11 PM
04/07/16 02:11 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hi Mick, yes they are the same except,
1. some oilpumps require longer lengths to engage the pump,
the pump manuf. should tell you this.
2. roller cams require bronze gears on the drive to work with the roller cam cores.
Don
Re: oil pump drives [Re: deaks] #2048936
04/07/16 04:28 PM
04/07/16 04:28 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks Don
I have two anyway same length both used with the melling hi vol pump, one with the bronze gear and the other out of the short block you sold me.
Mick
best 60ft 1.36
