Re: No brakes!
[Re: Hotlumpy]
#2048456
04/06/16 11:45 PM
04/06/16 11:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
did you bleed the master cylinder?
If not you may have air in it.
Re: No brakes!
[Re: Hotlumpy]
#2048481
04/07/16 12:02 AM
04/07/16 12:02 AM
Supercuda
About to go away
About to go away
up yours
Did you use the 74 combination valve? If so the shuttle might be over to one side blocking flow, you may need to recenter it.
Re: No brakes!
[Re: Hotlumpy]
#2048557
04/07/16 01:41 AM
04/07/16 01:41 AM
RapidRobert
you did the conversion & all was well for a period of time then later on you changed the front hoses & the prob started? As said (1) bleed the MC (2) bleed the fronts (3) bleed rears if needed. put a block of wood under the pedal so it only goes to ~where it depressed to when it was good. there are speed bleeders but an old fashioned helper works good for bleeding
Re: No brakes!
[Re: Paul_Fancsali]
#2049087
04/07/16 06:55 PM
04/07/16 06:55 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Bleeder on top of caliper? I'm guilty of that
When it takes more than a sweet mullet to prove you rule at the trailer park..
