Page 3 of 3 1 2 3
Re: molnar crank and rods machined quality? [Re: challenger451ci] #2048005
04/06/16 03:06 PM
04/06/16 03:06 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
which bearings did you go with? not sure what other brand cranks for 400B are offered in the 4.150 stroke with 2.200 rod journals, but i may just go on price alone if i have to have the crank machined anyway. i dont think the main bearings for the B engine are offered in over sizes(thinner) like a +.001 for instance. that would have been nice.
Re: molnar crank and rods machined quality? [Re: Hemi_Joel] #2048311
04/06/16 09:18 PM
04/06/16 09:18 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted By Hemi_Joel
I prefer an analog gauge, graduated to .0001. That way, I can see it sweep towards zero, and very easily take a reading off the needle, without having to digest a bunch of moving numbers. IMHO, .0001 is essential, .0005 is too vague.
Totally agree. I do a lot of work with shops and teach them measuring. No one uses a digital one.
Re: molnar crank and rods machined quality? [Re: markz528] #2048376
04/06/16 10:30 PM
04/06/16 10:30 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. Are the shars dial indicator any good? Which is most accurate a .250 dial or a .125 dial both with incerments of .0001?
Re: molnar crank and rods machined quality? [Re: mopar dave] #2048386
04/06/16 10:38 PM
04/06/16 10:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By mopar dave
Ok. Are the shaps dial indicator any good? Which is most accurate a .250 dial or a .125 dial both with incerments of .0001?
one will be just as accurate as the other regardless of travel length.
Re: molnar crank and rods machined quality? [Re: Runner] #2048719
04/07/16 11:08 AM
04/07/16 11:08 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Originally Posted By Runner
i must have either got luck or muscle motors cleaned it up. my machinest said my was really nice.
I agree. And I said, I bought some additional bearings in + increments just in case I needed them at assembly. I didn't use them.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: molnar crank and rods machined quality? [Re: mopar dave] #2048728
04/07/16 11:18 AM
04/07/16 11:18 AM
an8sec70cuda Offline
I have a Molnar rotating assembly for a 540" hemi out in the shop that we got from Dan at Performance Only. As far as I know, it needed no corrective machining and he spoke very highly of their products.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: molnar crank and rods machined quality? [Re: an8sec70cuda] #2048763
04/07/16 12:06 PM
04/07/16 12:06 PM
Mt Morris Michigan
Mt Morris Michigan
not much of a selection here for the lo deck, but i'm leaning toward the molnar crank and rods. second choice would be 440source. thanks guys
Re: molnar crank and rods machined quality? [Re: mopar dave] #2049142
04/07/16 07:47 PM
04/07/16 07:47 PM
NY
challenger451ci Offline
NY
I wasn't able to find any 400 mains in +/-0.001" sizes. I used the chamfered Clevites that Hughes sells. Had to get a second set(0.010" under) when I couldn't get much more than 0.0025" clearance on the std mains. King makes a 400 main bearing, but they steered me to Clevites when I told them I'd be using a decent amount of nitrous. They said their bearings don't provide enough support for a nitrous application.
To clarify....not ALL King bearings, just the series they offer for a low deck Mopar!
Re: molnar crank and rods machined quality? [Re: challenger451ci] #2049183
04/07/16 08:32 PM
04/07/16 08:32 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah. King doesnt offer a full groove neither.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2049231
04/07/16 09:38 PM
04/07/16 09:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Dave What about MB555AM king bearings, those are full groove for the lo decks.
Re: molnar crank and rods machined quality? [Re: dartman366] #2049284
04/07/16 10:39 PM
04/07/16 10:39 PM
Mt Morris Michigan
Mt Morris Michigan
King told me they do not have a performance bearing in a full groove for the 400 block. So that full groove you mentioned must be a stock replacement bearing like the 4094m federal mogul.
Re: molnar crank and rods machined quality? [Re: mopar dave] #2049385
04/08/16 12:39 AM
04/08/16 12:39 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I bought Molnar crank and rods for my engine last summer. I was very impressed with them both. All main and rod journal were .0005" under sized (for extra clearace I'm guessing), but they were all the same, zero taper anywhere. Only thing that I had to do to the crank was balance it, and it didn't take much to do that.
The rod bushings were sized correctly out of the box (unlike the previous set (differnt mfg) that I bought that the pin wouldn't go into at all, another trip to the machine shop and more $'s)
If I were going to buy a crank today, my first choice would be Molnar.
Brian
Re: molnar crank and rods machined quality? [Re: '72CudaRacer] #2049430
04/08/16 01:59 AM
04/08/16 01:59 AM
Mt Morris Michigan
Mt Morris Michigan
ok. iv got it narrowed down to molnar than 440 source. source has an ultra lite 4.250 lo deck crank if i go that route.
Page 3 of 3 1 2 3
