arias hemi piston/wall clearance issue........ #2047987
04/06/16 02:52 PM
04/06/16 02:52 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I had a local shop build a hemi shortblock for me and I am re-assembling it now,(had to take it apart due to insufficient rod side clearance)they set the piston to wall clearance at 0065 ,at their discretion,I did not have a spec sheet from arias.I called arias today and the guy there said the pistons are 4032 and should be run at 0025.What now?,do I order new pistons,have the skirts coated on these ones or just run it? this is a stock street/restoration engine,4.26 bore 3.75 stroke.......
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2047998
04/06/16 03:00 PM
04/06/16 03:00 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I was reading on another site they can coat it to +.002 and that would take up .004 but the combustion area above the rings would be loose and that may not be so good.Depending on your budget I think new is best.
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048003
04/06/16 03:03 PM
04/06/16 03:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d be having them make it right then find another machine shop........
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048038
04/06/16 03:39 PM
04/06/16 03:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Run it
Re: arias hemi piston/wall clearance issue........ [Re: FastmOp] #2048045
04/06/16 03:49 PM
04/06/16 03:49 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Wont happen,nobody takes responsibility for anything anymore,but I am done with them for sure...
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048056
04/06/16 03:59 PM
04/06/16 03:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'd run it. .006-.008 is pretty common on forged pistons. Like was already mentioned, coat it if your really concerned. Good luck
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048071
04/06/16 04:10 PM
04/06/16 04:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The clearance on the pistons is not the only reason why I`d look elsewhere, it`s the too tight rod clearances also..........they got it all backwards period.............
Re: arias hemi piston/wall clearance issue........ [Re: Thumperdart] #2048077
04/06/16 04:19 PM
04/06/16 04:19 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
For sure. As I'm sure you know, tight rod side clearance can lead to a major failure. If your piston to wall is a little loose, it's no worse off than it would have been with some normal wear in a couple years. $1200+/- for a new set of slugs is more than I would spend to solve a minor problem that probably won't be noticeable other than a little noise when its cold. I've assembled engines putting used pistons back in their bores after a straighten up hone that had .010+ clearance with no issue except noise. Not ideal, but not a disaster either.
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048105
04/06/16 04:50 PM
04/06/16 04:50 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
FOr ours we followed JE instructions and got a 0.005" skirt clearance for our 4" bore JE pistons. So honed to 4.005".
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048122
04/06/16 05:14 PM
04/06/16 05:14 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Dosent .0025 sound tight for a forged piston???
JAKES AUTOMOTIVE
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048126
04/06/16 05:21 PM
04/06/16 05:21 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My new Diamonds call for .006". My Weisco were run at .007". Line to Line Coatings in Michigan can build them up if needed. Plenty of positive reviews even on high buck race motors.
Doug
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048194
04/06/16 06:37 PM
04/06/16 06:37 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have no personal experience with them, but I have read that 4032 aluminum has more silicone than traditional forged pistons so they expand 15% less. Thus they can be run tighter.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: arias hemi piston/wall clearance issue........ [Re: Hemi_Joel] #2048271
04/06/16 08:22 PM
04/06/16 08:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If they should definetly be at .0025 then you could knurl the pistons and then file fit them as I have done that on worn engines before when I used stock bore pistons on cylinders .002 or .003 oversize. Knurling raised the surface and once they are knurled they may not even fit in the cyl as you then file fit them. It actually works very good and is an old trick of years ago. But the knurls hold some oil in them so it keeps some oil on the side of the piston. I ran knurled pistons in a 383 that worked good and did not burn a drop of oil. But be sure as .0065 sounds in the ballpark for a forged piston. I know I run my 440Source pistons at about .006. Ron
Re: arias hemi piston/wall clearance issue........ [Re: ogopogo] #2048350
04/06/16 10:00 PM
04/06/16 10:00 PM
British Columbia Canada
Challenger340 Offline
Do you know the Compression Distance on the Piston ? or the break point on the skirt ?(pin center DOWN to the tang end)
While 4032 alloys do run tighter than 2618 alloys, I would not really sweat the .0065 Clrc on a long skirt like a stock type piston, which sounds like you have ?
A little high yes, but for stock street type stuff generally speaking, 4032 cam & barrel stuff goes in around .0030" to .0035", with an additional .001" to .003" advised depending on rpm, compression, nitrous or boost(4032 are only good for very light N02 or boost anyways).
They might rattle a bit at .0065", but they'll run fine, 20W-50 maybe to quiet them down ?
Better to be a "has been" than a "never was".
Re: arias hemi piston/wall clearance issue........ [Re: JAKE68] #2048359
04/06/16 10:08 PM
04/06/16 10:08 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Ummmm, YEA. I wouldn't do it.
Re: arias hemi piston/wall clearance issue........ [Re: cudadoug] #2048374
04/06/16 10:29 PM
04/06/16 10:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I put a basterd 360 motor together out of mismatched pistons and block. It has .007 clearance with kb hypers. laugh2 thats a big no no i guess. tsk just dont tell some circle track guys that, some of them run them way loose. That 360 doesn't make any scary noises at all. Maybe it will someday. Oh well.
Re: arias hemi piston/wall clearance issue........ [Re: FastmOp] #2048410
04/06/16 10:59 PM
04/06/16 10:59 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By FastmOp
Run it
Yep! Not gonna be a problem.
Fastest 300
