A body k frame #2047460
04/05/16 10:44 PM
04/05/16 10:44 PM
Iowa
beaver77 Offline OP
beaver77  Offline OP
Iowa
Can anyone tell me what I can interchange between a 1967 to 1972 k frame and the 73 up k frame. Thanks
Re: A body k frame [Re: beaver77] #2047473
04/05/16 10:50 PM
04/05/16 10:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure what you are asking. Are you asking "what bolts to the 67-72 K frame that will also bolt to a 73 and up K frame"?
Don't be the exception.
Re: A body k frame [Re: Supercuda] #2047487
04/05/16 11:04 PM
04/05/16 11:04 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
LCA and strut rods interchange as does the steering box and torsion bars. The pitman arm, idler arm and center link do not interchange. If you have a 67-72 K and are looking to use a 73 K the motor mounts 73 up are spool mount. The whole brake scenario will depend on what you want to use for spindles as to whether you also need upper control arms. shruggy
...FAFO...
Re: A body k frame [Re: skicker] #2047514
04/05/16 11:24 PM
04/05/16 11:24 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Lets not forget the 67 idler arm is different as the 67 k-frame has a single mount point while the 68-up has the idler sandwiched between two mounts. Everything will interchange if you use the correct early or later parts in combination.
JB Rhinehart, Realist
A-Body's RULE!
Re: A body k frame [Re: Rhinodart] #2047537
04/05/16 11:44 PM
04/05/16 11:44 PM
Iowa
beaver77 Offline OP
beaver77  Offline OP
Iowa
I will clarify I need to know if the a arms torsion bars and drag link off a 73 k frame will work on a 70 k frame. I want to use disc brakes and a arms off 73 on a 70. Thanks for the help
Re: A body k frame [Re: beaver77] #2047563
04/06/16 12:13 AM
04/06/16 12:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
control arms - yes
torsion bars - yes
drag link - it's called a center link and usually doesn't need to be swapped as it's a non-wear item but if you use the corresponding 73 and up idler and pitman arm then yes.
Re: A body k frame [Re: beaver77] #2047588
04/06/16 12:43 AM
04/06/16 12:43 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The center link swaps over if the Idler, Pitman and tie rods are all from either 68-72 or 73-76.
Torsion bars and upper control arms fit from 1960 to 1976 ! The only difference is that cars with 10" drums up front or 73-76 Disc brakes use a different UCA with the bigger upper ball joint.
This forum can be very helpful. We like the questions to be clear and easy to read and understand. Nobody I know likes to read posts that look like they are thrown together like a 11 year old girl texting her friends.
NOT pointing a finger at the OP, just a friendly reminder.
Re: A body k frame [Re: beaver77] #2047592
04/06/16 12:49 AM
04/06/16 12:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Certain sets of parts can interchange on their own.
There are 3 k-members: 67, 68-72, and 73-76. 67 is on its own because it take a one year only idler arm
There are 3 steering linkage systems
67-72 centerlink, 67-72 pitman, small output 72-down power steering box, and 67 idler all together can only fit 67 k-member.
68-72 centerlink, 67-72 pitman, small output 72-down power steering box, 68-72 idler all together can interchange between 68-72 k-member or 73-76 k
73-76 centerlink, 73-76 pitman, large output 73-up power steering box, 73-76 idler all together can interchange between 68-72 k-member or 73-76 k
There are 2 disk brake systems
67-72 Kelsey Hayes 4 piston disks. 67-72 small diameter upper ball joint upper control arms, 67-72 disk brake ball joint spindles. Will bolt to any 66-76 lower control arm and only 66-72 upper control arms.(excluding 9" drum brake cars)
73-76 single piston slider type disks. 73-76 large ball joint upper control arms, 73-76 lower disk brake ball joint, and spindles. Will bolt to any 66-76 lower control arm and 73-76 upper control arms (excluding 9" drum brake cars).
The above steering linkage OR brake systems can be swapped between each other on either 68-72 k-member OR 73-76 k-member.
Re: A body k frame [Re: Kern Dog] #2047606
04/06/16 01:12 AM
04/06/16 01:12 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Only 73-76 cars used the large upper ball joint.
