340 Stock Stroke Street Build Recipie For a 73 B-body #2041544
03/29/16 11:30 PM
03/29/16 11:30 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm looking to help a buddy who wants to wake up his 1973 340 Charger. Looking for a pump gas engine with a stock stroke and stock iron 915 heads with a good valve job and pocket port, stock exhaust manifolds, with a stock TQ carb and and intake that will work with it. Shooting for stock look but with more power.
I know I'll hear this a lot (I preach it myself) but a stroker is not an option
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2041573
03/29/16 11:56 PM
03/29/16 11:56 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would go with the KB243 piston and work hard on getting the quench good. It will be right around 10:1 if I remember and with the quench it will likely not have any problems with pump fuel. I can't help much with the manifolds and carb but getting as much compression as you can on pump fuel doesn't hurt.
I had a stock stroke 340 in my car in high school and modified more as time went on. It had the KB243s with good quench and ran on 93 octane for years with no trouble. Once I had the X heads ported and used a good converter it went 11.98@114 in good air. I want to build that motor again for something else someday, it was fun.
68 Barracuda Formula S 340
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2041668
03/30/16 02:00 AM
03/30/16 02:00 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
well you already know the stock manifolds will kill a lot of power. all i can add is i run 11.25cr with J heads and speed pro flat tops, the heads have been milled a lot 59cc. 195 cranking psi. runs good on 93 with very cold plugs. a lot of torque and nice pop out of the exhaust!
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2041741
03/30/16 09:13 AM
03/30/16 09:13 AM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
Extrude Hone the buggery out of those exhaust manifolds? What about stock Eliminator I've got a recipe for all the tricks for a Bob Lambek h/s build I could dig the book out if you want.I think I know where it is it was only 1992😆
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: coletrickle] #2042427
03/31/16 01:10 AM
03/31/16 01:10 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
How about some cam numbers. Remember, pump gas, heavy car, street driven
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2042474
03/31/16 02:25 AM
03/31/16 02:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Interesting question: you could go with a torque build and give up peak HP, or throw alot of gear and converter in the car and make a high winding HP engine, but with the stock exhaust and intake your really limited the RPM range and HP, so need to focus on torque and high VE in the low to mid RPM range. If you can still get some gear and higher converter stall, you can tighten up cam LSA to help the mid to upper range while still running smaller duration lobes.
I'm thinking something like the Hughes 223/236 Whiplash cam, but 9.5-10:1 compression?
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2047002
04/05/16 12:18 PM
04/05/16 12:18 PM
Earth
Rob C Offline
Rob C  Offline
Earth
What's the gear ratio and tire size?
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: coletrickle] #2047040
04/05/16 12:57 PM
04/05/16 12:57 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Extrude hone maybe 3-4hp for $500 bucks. Not worth it imo. Stock brackets recipe call for stock lift cams running 350* duration & 7000rpm. Not exactly street friendly.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2047111
04/05/16 02:17 PM
04/05/16 02:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You can only wake up a stock motor so much if most of it is going to remain stock.
Push the cr as high as you dare, little bit of a cam(solid lifters would be worth a little something), mild bowl port on the heads, 2.02 valves.
Not really much else that will fit the rest of the criteria.
For sure, the absolute best way to really enhance the fun factor for that type of project is a stroker. Anything else will be way way less effective.
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2047158
04/05/16 03:19 PM
04/05/16 03:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Is he open at all to aftermarket heads?
Heads like iron W-2's give tremendous gains and kinda disappear after painted and all the accessories are installed.
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: GY3] #2047250
04/05/16 05:26 PM
04/05/16 05:26 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
What gear? Any type of converter? Low gear trans an option?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: fast68plymouth] #2047374
04/05/16 08:49 PM
04/05/16 08:49 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is the answer. Take the 340 out and store it for someone that has to have a 340 and is willing to pay stupid money for it. If you want the 340 look, get a 318 core, bore it .030 and fit it with a cast 4" crank and at least 9 to 1 pistons. A mild cam and 4 barrel will run well on today's gas. JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2047397
04/05/16 09:31 PM
04/05/16 09:31 PM
Earth
Rob C Offline
Rob C  Offline
Earth
OK, here is my flying blind answer;
Comp cams has a line designed just for exhaust manifolds.
Crane cams for years has been making cams with extra duration.
Larry Shelard has said to use cams like this in unported or mildly ported heads since the exhaust is poorer flowing and could use the help with a longer duration.
Choose the cam with the cruise rom range in mind that fits the driving rom range.
If you are changing the converter, Comp Cams biggest exhaust manifold cam is good to go with and a mild converter.
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049209
04/07/16 09:12 PM
04/07/16 09:12 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
Scott,
Since the pistons have been discussed, Lets talk camshaft, converter and gear.
How about the good old XE268
18-20 degrees initial timing, 36 total at about 1800RPM and another 15 degrees in the can for cruising
A "tight" 10" converter with at least a 3.73 gear since I'm sure he'll be running something like a 255/60-15 in the back.
Shift @ 6000Rpm
1971 6.1 Gen III Hemi Duster
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049324
04/07/16 11:31 PM
04/07/16 11:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd want to know what gear & tire and how he wants to use the car, and whether he wants to spin the motor or not.
For street use, I've had better results with lift than duration.
Obviously a stroker allows a taller gear for highway use. Might even be fairly cost-effective depending on the engine's existing condition and finding a deal somewhere.
All the usual stuff applies, like detailed tuning efforts, better exhaust system, maybe 2400 stall, and/or more gear.
Then there's weight reduction, if that's an option.
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049441
04/08/16 02:43 AM
04/08/16 02:43 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Why is a stroker not a option? Thats not going to be a very fast car with exhaust manifolds. even if he spends a ton on ported intake and max 915 heads with 2.05's valves, if CR is pump gas friendly its probably a 350hp motor but in that body a 14 second car in street trim
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049512
04/08/16 09:48 AM
04/08/16 09:48 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
for a huge car like that increasing the cam or head flow may
be the worst thing you could do.A bit of lift and less duration
would be better.
there is not a lot you can do with a small engine in a huge
car.A gear and a converter will help as well.
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049549
04/08/16 10:47 AM
04/08/16 10:47 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
268 XE would be very lazy in a big car like that until about 40 or 50 mph.
how about the generic 204 / 214, .429 / .444....good lo end torque.
that should break the tires loose and pull good beyond the speed limits
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: can.al] #2049561
04/08/16 11:09 AM
04/08/16 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I never ran a 340 in a B-body but when I was
running stock stroke 340s in A-bodies on the
street I always started at the back of the car..
I started with a gear in back then conv then worked
on the engine... in 340s the valve springs were always
the weak link.. I would change them even if it was the
stock cam so it could rev a bit more
wave
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ademon] #2049580
04/08/16 11:41 AM
04/08/16 11:41 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Why ask why ? Just work the issue. You can argue all you want for a stroker. But it is simply just NOT on the option list.
