Re: Rear Sump Oil Pan ?
[Re: Bigbeep]
#204650
01/26/09 10:10 AM
01/26/09 10:10 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Sorry forgot to mention I'm not going to use the pick up or the dipstick my plan is to modify the steel pan to a dry sump pan by welding in -12 AN bungs and possibly save $300 I'm gonna use a rear sump since it'll clear an AlterKation but just not sure if it'll clear my 4.5 stroke thanks
[Re: VernMotor]
#204654
01/26/09 11:53 PM
01/26/09 11:53 PM
Posts: 777 Eastern WA
ProStock1320
Eastern WA
I need a pan like that for my dart..since I move the motor back..is from MA-mopar ?
Under the picture it lists P5249064.
[Re: RylisPro]
#204656
01/27/09 11:20 AM
01/27/09 11:20 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Why not just get a proper dry sump type pan??? Plenty of HP can be found in the right oil pan.
[Re: Al_Alguire]
#204657
01/27/09 11:46 AM
01/27/09 11:46 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I can easily add baffles for oil control and combined with a crank scraper and with the bungs welded in the right postion, I'm guessing it will function just as good as a fancy fabricated pan also I'll feel better with the strength of steel vs. aluminum under a street car driving over potholes and what not finally I'll only spend about $100 bucks into the experiment and if it all goes wrong, I'll get a proper dry sump pan
