Rear Sump Oil Pan ? #204647
01/26/09 12:45 AM
01/26/09 12:45 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Need to know if this Rear Sump Oil Pan P5249064
will clear a 4.5 stroke
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear Sump Oil Pan ? [Re: RylisPro] #204648
01/26/09 01:27 AM
01/26/09 01:27 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
thanks
I dunno, if no one else knows, maybe you can borrow a BB truck pan from someone local to you to find out?
**Photobucket sucks**
Re: Rear Sump Oil Pan ? [Re: 70Cuda383] #204649
01/26/09 01:32 AM
01/26/09 01:32 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
If no one chimes in, I have a pan around here that I can measure from the pan rail down to the floor of the pan. I would think that the pick up would be the clearance problem. Beep
Re: Rear Sump Oil Pan ? [Re: Bigbeep] #204650
01/26/09 10:10 AM
01/26/09 10:10 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Sorry forgot to mention
I'm not going to use the pick up or the dipstick
my plan is to modify the steel pan to a dry sump pan by welding in -12 AN bungs and possibly save $300
I'm gonna use a rear sump since it'll clear an AlterKation but just not sure if it'll clear my 4.5 stroke
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear Sump Oil Pan ? [Re: RylisPro] #204651
01/26/09 01:37 PM
01/26/09 01:37 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
maybe go with a dragster style pan and gain some ground clearance. I think there 5" deep in the rear.
Re: Rear Sump Oil Pan ? [Re: 70blackfish] #204652
01/26/09 03:04 PM
01/26/09 03:04 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I was just gonna cut down the sump to about 2.5" since AN -12 female bungs are 2" dia.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear Sump Oil Pan ? [Re: RylisPro] #204653
01/26/09 04:10 PM
01/26/09 04:10 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I need a pan like that for my dart..since I move the motor back..is from MA-mopar ?
Re: Rear Sump Oil Pan ? [Re: VernMotor] #204654
01/26/09 11:53 PM
01/26/09 11:53 PM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
Under the picture it lists P5249064.
Re: Rear Sump Oil Pan ? [Re: ProStock1320] #204655
01/27/09 04:03 AM
01/27/09 04:03 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
440 Source has used ones part number 100-1064
I should be fine with a 4.5 stroke since I'm not going to use the oil pickup
I'll post pics when I get one and modify it for dry sump
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear Sump Oil Pan ? [Re: RylisPro] #204656
01/27/09 11:20 AM
01/27/09 11:20 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Why not just get a proper dry sump type pan??? Plenty of HP can be found in the right oil pan.
Re: Rear Sump Oil Pan ? [Re: Al_Alguire] #204657
01/27/09 11:46 AM
01/27/09 11:46 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I can easily add baffles for oil control and combined with a crank scraper and with the bungs welded in the right postion, I'm guessing it will function just as good as a fancy fabricated pan
also I'll feel better with the strength of steel vs. aluminum under a street car driving over potholes and what not
finally I'll only spend about $100 bucks into the experiment and if it all goes wrong, I'll get a proper dry sump pan
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Rear Sump Oil Pan ? [Re: RylisPro] #204658
01/27/09 04:53 PM
01/27/09 04:53 PM
If it won't clear I have several 1/4 inch billet aluminum BB and Hemi oil pans spacers in stock, $75.00 plus shipping, PM me if you end up needing one
