Re: Aluminum heads
[Re: can.al]
#2045086
04/03/16 08:18 AM
04/03/16 08:18 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Old 451 - B1-B/S Head 11:1 compression (no quench, entire piston dished) 251/251@0.050 Solid Roller, 33* total timing. OK on pump gas, usually ran 50% pump/50% 110 race gas when I raced it just to be safe.
These next two have about 0.040" quench
New 499 - Victor MW Head, 12.4:1 compression, 272 (or 274, I forgot)@ 0.050 Solid Roller, 34-36 Total timing (still tuning.) Ran OK on pump gas for a very limited time, and did not try WOT on pump, usualy ran on 110 race gas or mix of race and pump. Switched to E-85 last year and still tuning it.
505 - Stealth heads. A bit over 10:1 (I think 10.3:1?), 236/242@ 0.050 hydraulic Roller. EFI so timing varies with load and I'm still tuning this. Pump gas only, but it has pinged before (don't know the exact timing because I was using the Edelbrock XT hand-held EFI controller and changing the global timing.
Re: Aluminum heads
[Re: can.al]
#2045390
04/03/16 02:53 PM
04/03/16 02:53 PM
Thumperdart
State of confusion
12.1.1 comp home ported rpm`s(no flow #`s)Isky solid roller .680-.660 276-281 @ .050 timing locked at 35..............470 BB stroker Street car...........
Re: Aluminum heads
[Re: can.al]
#2045427
04/03/16 03:24 PM
04/03/16 03:24 PM
Posts: 77 British Columbia Canada
Challenger340
Street or Race ? Lots of Race responses, so I'll give a "Street" We just put 10.8:1 static on some Ported Stealths, used an XS282S Comp Solid Flat Tappet with 1.6 Rockers... good for 587 hp/ 592 Trq on the SF902 with 91 Octane, 33* BTDC
Better to be a "has been" than a "never was".
Re: Aluminum heads
[Re: Challenger340]
#2045433
04/03/16 03:32 PM
04/03/16 03:32 PM
Posts: 5,167 CT
GTX MATT
CT
Street or Race ? Lots of Race responses, so I'll give a "Street" We just put 10.8:1 static on some Ported Stealths, used an XS282S Comp Solid Flat Tappet with 1.6 Rockers... good for 587 hp/ 592 Trq on the SF902 with 91 Octane, 33* BTDC Thats some serious power, how ported were these Stealths?
Re: Aluminum heads
[Re: GTX MATT]
#2045440
04/03/16 03:39 PM
04/03/16 03:39 PM
Challenger340
Street or Race ? Lots of Race responses, so I'll give a "Street" We just put 10.8:1 static on some Ported Stealths, used an XS282S Comp Solid Flat Tappet with 1.6 Rockers... good for 587 hp/ 592 Trq on the SF902 with 91 Octane, 33* BTDC Thats some serious power, how ported were these Stealths? We Ported a very Fat curve on our SuperFlow SF750 Bench, but just under 300cfm @ .600". I can post the Flow Sheet if you like ? but off my head I think 285cfm by .500", 291cfm @ .550" and 297cfm @ .600". About 10-12 Hours Port & prep. NOT cost effective to spend any more on what is really an "entry level" Cylinder Head ?
Re: Aluminum heads
[Re: can.al]
#2045547
04/03/16 05:08 PM
04/03/16 05:08 PM
Posts: 5,167 CT
GTX MATT
CT
Was that a stock stroke 440?
Re: Aluminum heads
[Re: can.al]
#2045613
04/03/16 06:49 PM
04/03/16 06:49 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
10.9 compression, timing locked at 35*. 394 ci small block runs on 93 octane. 255/266 @.050
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Aluminum heads
[Re: Challenger340]
#2045812
04/03/16 11:38 PM
04/03/16 11:38 PM
Posts: 5,167 CT
GTX MATT
CT
Was that a stock stroke 440? 400 Block based "451", but yes stock 3.75" (440)Stroke. Thats a strong running engine, darn impressive for a somewhat mild cam
Re: Aluminum heads
[Re: can.al]
#2045913
04/04/16 01:16 AM
04/04/16 01:16 AM
Posts: 9,883 MI, usa
dvw
MI, usa
572", Indy -1 , 58 cc, 15-1, flat top w/10cc notches, .005" deck height, 285/292@112, LCA, 32 degrees, Renegade 114 or 116 fuel, no quicker with more timing. Doug
Re: Aluminum heads
[Re: can.al]
#2046303
04/04/16 03:16 PM
04/04/16 03:16 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I run Stealths with 12.5 domes on the street.Cam is Comp .588 lift and IIRC around 320 duration.Run 34 timing on my MSD.It will clatter under heavy load with 93.If I dont really get into it I can drive foreve on 93.Mix in some 110 race fuel and its good all around.Rocky
Chrysler Firepower
Re: Aluminum heads
[Re: can.al]
#2047510
04/05/16 11:22 PM
04/05/16 11:22 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
was 10.2:1 on Indy-1 255 cnc raised port heads and 408 cubes New will be 11.5:1 with same heads and 410 cubes, still rocking that 93 pump gas ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
