Re: Carter AVS or Holley?
[Re: ChuckinNY]
#2044744
04/02/16 09:37 PM
04/02/16 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: ChuckinNY]
#2044911
04/03/16 12:08 AM
04/03/16 12:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
three things that take no imagination
SBC
Holley Carb
Ford 9"
look at any generic street rod.
[Re: ChuckinNY]
#2044987
04/03/16 01:40 AM
04/03/16 01:40 AM
RapidRobert
All (OE '68-'71) AVS's are lean from Ma trying to meet the discombobulated Federal emission standards of the day (Furd/Chebby too). convert it to use Eddy Performer 2 step metering rods/jets. Fill the domed metering rod caps with JBweld then cover it with scotch tape then turn it over & let it set for 2 days so the mud will settle & harden out level then pull the scotch tape. Start with a rod/jet combo several tho larger (richer) than (AVS) stock on the power/cruise steps & go from there. Purchase a strip kit with rods/jets close to the dia's your AVS has
[Re: ChuckinNY]
#2045003
04/03/16 02:13 AM
04/03/16 02:13 AM
Posts: 10,210 Someplace you aren't
SomeCarGuy
The avs will be fine. The holley will be fine. Which do you feel most comfortable working on? Sounds like the car is mostly stockish so the avs woukd look more "correct" and you likely have the oem fuel line already.
I want my fair share
[Re: ScottSmith_Harms]
#2045004
04/03/16 02:16 AM
04/03/16 02:16 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I agree, nothing wrong with the stock AVS at all. Without a doubt... Leave the 'MP' fer someone else...
[Re: ChuckinNY]
#2045147
04/03/16 10:28 AM
04/03/16 10:28 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
If you are not set on 100% stock and have a little $ to spend why not try the Street Demon carb? Youd have a brand new carb and its intended target is high perf street driven vehicles.
Keep old mopars alive.
[Re: ChuckinNY]
#2045175
04/03/16 11:25 AM
04/03/16 11:25 AM
Posts: 3,916 usa
lewtot184
usa
Its a 69 GTX...440 auto with ac.Mostly original.It had a repaint many years ago and its a nice driver. I have a feeling I cant go wrong with which ever carb I go with! look at the front of the carb and see if the numbers 4640s are stamped on it. i have a '69 r/t 440 auto with it's original 4618s avs. what i've done is change out the leather accelerator pump plunger for newer viton edelbrock. i use the stock .101 tall primary jets with a 16-575 metering rod (.065/.060/.052 three step. these are no longer available but an edelbrock .065/.052 will work). stock .095 jets in the back will work with a stock engine. i've unplugged the mixture screws at the base of the carb and they're backed out 3 1/2 turns. the only "tricky" part is the idle jet. it's the small brass tube that hangs out the bottom of the primary cluster. these are .031" from the factory, too small. i've tried several sizes from .031" to .040". i've settled on .033" which is a tad lean (manual transmission carbs used .035" which is about right). i use a .028" afb squirter i modified to fit the avs (simple to do) and have the pump shot rod in the top hole. this carb starts, drives and performs quit well with the near stock engine (summit 6401 cam; idles smooth, very good low end). keeping the avs lets retain all the stock linkage and choke assembly and you give absolutely nothing up in performance to a comparable holley.
[Re: ChuckinNY]
#2047533
04/05/16 11:39 PM
04/05/16 11:39 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
it is a 4640s. I still have the metal tag that mounts on the base of the carb with 4640s stamped on it. Chuck, I'd say rebuild the AVS and start there. If you don't like it, try the Carter. I switched my 1967 2bbl 383 Satellite over to an AVS 8 years ago, never regretted it for a moment. I'm not a performance guru, but like to have some power. Easy to rebuild, easy to drive, no fuss no muss. You've got the tag, so for a kit just call Larry Isgro Carburetors, he is on Long Island unless he retired, but I've been getting my rebuild kits from him since 2001. http://www.yelp.com/biz/larry-isgro-carburetors-wantaghBest, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: Supercuda]
#2047551
04/05/16 11:58 PM
04/05/16 11:58 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
SBC
Holley Carb
Ford 9"
look at any generic street rod. LOL The Holley 4150 is an engine fire waiting to happen If you have the Carter 4640S use it
