AMD 69 coronet 1/4s and outer wheelhouses #2034774
03/19/16 11:42 PM
03/19/16 11:42 PM
Marion,Indiana
Seth_Jones Offline OP
Marion,Indiana
Any problems to look out for? Getting ready to install both sides on my 69 bee. Trunk extensions too
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: Seth_Jones] #2034853
03/20/16 02:38 AM
03/20/16 02:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Check the actual side marker fit, and recessed side marker stamping to see if it's correctly placed and sized on the qtr, and check the end cap fit on the qtr, easier to rework these section before install
The AMD trunk extension might leave something to be desired as far as fit/function, I've found the Goodmark B body trunk extensions a better fit with less work when used with AMD rear qtrs
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: DAYCLONA] #2044708
04/02/16 09:04 PM
04/02/16 09:04 PM
Marion,Indiana
Marion,Indiana
The AMD left side trunk extension doesn't even fit the AMD 1/4 correctly at the rear....
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: Seth_Jones] #2044751
04/02/16 09:40 PM
04/02/16 09:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
re-read my earlier post...
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: DAYCLONA] #2045573
04/03/16 05:46 PM
04/03/16 05:46 PM
Marion,Indiana
Marion,Indiana
Why re read your post? This picture illustrates the problem. The initial fit of the 1/4 is very encouraging though...
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: Seth_Jones] #2045625
04/03/16 07:22 PM
04/03/16 07:22 PM
Albuquerque
69Boss302 Offline
69Boss302  Offline
Albuquerque
Maybe they sent you a RR trunk extension. It's happened to me before.
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: 69Boss302] #2045678
04/03/16 09:08 PM
04/03/16 09:08 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
trunk extension have the same part # dodge or plymouth
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: Seth_Jones] #2045769
04/03/16 11:03 PM
04/03/16 11:03 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
I think Mike is saying that he has had better experience fitting Goodmark trunk extentions.
Re: AMD 69 coronet 1/4s and outer wheelhouses [Re: 1969gtx] #2048417
04/06/16 11:05 PM
04/06/16 11:05 PM
Albuquerque
69Boss302 Offline
69Boss302  Offline
Albuquerque
You might want to look again as Dodge and Plymouth DO NOT have the same part number.
